[hpc-announce] Deadline Extension: Journal of Supercomputing S.I. : Vector Architectures and Applications in the Exascale Era
Juan Manuel Cebrián González
jm.cebriangonzalez at gmail.com
Tue Nov 27 09:00:04 CST 2018
Deadline extension December 15, 2018.
Introduction.
Data-level parallelism (DLP) and thread-level parallelism (TLP) are
keystones to achieve Exascale computing under a reasonable power
budget. Both DLP and TLP are present in most modern supercomputers,
regardless of being based on accelerators (e.g., GPGPUs) and/or CPUs
(IBM Vector Media eXtension –VMX–, NEC SX architecture, Intel Advanced
Vector eXtension –AVX– and ARM Scalable Vector Extension –SVE–).
This special issue at the Journal of Supercomputing (ISSN: 0920-8542,
JCR Q2 1.532 Impact Factor) is looking for original research works to
explore the intersection between both algorithm design and hardware
improvements to deal with the emergent challenges of the upcoming
vector applications. In this regard, one of the main objectives of
this special issue proposal is discussing about the main trends in
vector parallel processing, algorithm definition and problem-domain
requirements altogether, which may anticipate future solutions to be
translated into real benefits to the society.
Topics
The goal of this special issue is to present the readers with novel
hardware enhancements, vectorization tools, codes and strategies as
well as current (and future) trends in vector architectures (CPUs,
GPUs or accelerators). Our goal is to cover the full development
stack, from applications to hardware. The target audience will be
application developers as well as academy and industry researchers
interested in improving vector codes and vector architectures. Topics
of interest, of both theoretical and practical significance, include
but are not limited to vector (CPU, GPU or accelerators):
- Programming framework
- Programming model and language explorations
- Compilation and optimization - including algorithmic improvements
and code optimization
- Performance Analysis and Debugging Tools
- Performance Metrics and Evaluations
- Libraries and run-time systems
- Design, generation, verification and validation of representative applications
- Case-studies of representative applications
- Innovative applications for vector architectures
- Hardware studies and micro-architectural implementation tradeoffs
Important Dates
- Submission Due December 15, 2018
Information for Authors
VAAEE Special Issue will follow the Journal of Supercomputing format
templates available here
(http://static.springer.com/sgw/documents/468198/application/zip/LaTeX_DL_468198_220518.zip).
Each article must not exceed 18 pages following the aforementioned
template, including references.
To submit your article follow the regular submission procedure for the
JSC Jorunal and then select the S.I. : Vector Architectures and
Applications in the Exascale Era as submission target instead of
regular submission.
Please check further details about Information for Authors at JSC
webpage (https://www.springer.com/computer/swe/journal/11227).
More information about the hpc-announce
