[hpc-announce] PMAM 2018 (deadline extended) -- jointly with PPoPP 2018
zhuang at cs.otago.ac.nz
Sun Nov 19 13:15:51 CST 2017
Call for Papers
The 2018 International Workshop on Programming Models and Applications for
Multicores and Manycores will be co-located with the PPoPP 2018 conference in
February 24-28, 2018, Vösendorf, Austria.
Rapid advancements in multicore and chip-level multi-threading
technologies open new
challenges and make multicore systems a part of the computing landscape. From
high-end servers to mobile phones, multicores and manycores are steadily
entering
every single aspect of the information technology.
However, most programmers are trained in sequential programming, yet most
existing
parallel programming models are prone to errors such as data race and
deadlock.
Therefore, to fully utilize multicore and manycore hardware, parallel
programming
models that allow easy transition of sequential programs to parallel
programs with
good performance and enable development of error-free codes are urgently
needed.
This workshop is dedicated primarily to gather researchers and practitioners
addressing the main challenges and share experiences in the emerging
multicore and
manycore software engineering and distributed programming paradigm. This
workshop
aims to provide a discussion forum for people interested in programming
environments, models, tools and applications specifically designed for
parallel
multicore and manycore hardware environments. Selected best papers of PMAM
will be
considered for publication in a special issue of high ranked journal
(Elsevier
Parallel Computing, PARCO).
The program committee cordially invites any novel research ideas in (but
not limited
to) the following topics:
• programming models and systems for multicore, manycore, and
clusters of
multicore/manycore
• multicore and manycore software engineering
• parallel and distributed algorithms on GPU and multicore
clusters
• parallel libraries and frameworks
• performance analysis, efficiency and effectiveness
• massively parallel processing on multicore/manycore systems
and clusters
• automated parallelization and compilation techniques
• debugging and performance autotuning tools and techniques for
multicore/manycore
applications
• parallel algorithms, applications and benchmarks on
multicore/manycore
systems
• runtime power/energy management on multicore/manycore
systems and clusters
• fault tolerance and resilience
Proceedings
All accepted papers will be published in the PMAM 2018 proceedings by the ACM
Digital Library, and will be included in the Elsevier databases Scopus and
Compendex
(EI indexed).
Selected best papers of PMAM will be considered for publication in a
special issue
of Parallel Computing (https://www.journals.elsevier.com/parallel-computing/
<https://www.journals.elsevier.com/parallel-computing/>).
Important Dates
• Paper submission deadline: November 29, 2017
• Notification of acceptance: January 1, 2018
• Camera-ready papers due: January 15, 2018
Papers reporting original and unpublished research results and experience are
solicited. All paper submissions will be handled electronically via
EasyChair.
http://www.easychair.org/conferences/?conf=pmam2018
<http://www.easychair.org/conferences/?conf=pmam2018>
Papers must not exceed 10 pages in standard ACM two-column conference format
(preprint mode, with page number and the 9pt template).
Authors must register and submit their paper through the online submission
system.
If you have problems accessing the system, e-mail your submission to:
pmam2018 at cs dot otago dot ac dot nz
For more details, please refer to:
https://ppopp18.sigplan.org/track/pmam-2018
<https://ppopp18.sigplan.org/track/pmam-2018>
For enquiries, please contact:
pmam2018 at cs.otago.ac.nz <mailto:pmam2018 at cs.otago.ac.nz>
More information about the hpc-announce
