[hpc-announce] Deadline Extended: TRANSACT 2017 - 12th ACM SIGPLAN Workshop on Transactional Computing / 9th Workshop on the Theory of Transactional Memory - Call for Papers
Paolo Romano
romano at inesc-id.pt
Wed Nov 30 08:16:16 CST 2016
Apologies in case of cross-posting
TRANSACT 2017
February 5, 2017
Austin, Texas, USA
In conjunction with the 22nd ACM SIGPLAN Symposium on Principles and
Practice of Parallel Programming (PPoPP 2017)
Website: http://transact2017.cse.lehigh.edu/
** Overview **
The past decade has seen an explosion of interest in programming
languages, systems, and hardware to support transactions, speculation,
and related alternatives to classical lock-based concurrency. Recently,
transactional memory has crossed two important thresholds. First, IBM
and Intel are now shipping processors with hardware support for
transactional memory (TM). Second, the C++ Standard Committee has been
working intensively to integrate TM as a new language feature. On the
other hand, the post-release discovery of an erratum in Intel’s hardware
TM implementation has brought upfront the need for effective TM
verification mechanisms. Overall, these developments highlight the
demand for continued high quality transactional memory research.
In 2017, Transact will be merged with the Workshop on the Theory of
Transactional Memory (WTTM); this will mark the twelfth Transact and
ninth WTTM. Transact 2017, will provide a forum to present and discuss
the latest research on all aspects of transactional computing. The scope
of the workshop is intentionally broad, with the goal of encouraging
interaction across the languages, architecture, systems, database, and
theory communities. Papers may address implementation techniques,
foundational results, applications and workloads, or experience with
working systems. Environments of interest include the full range from
multithreaded or multicore processors to high-end parallel and
distributed computing platforms.
** Topics **
The workshop seeks papers on topics related to all areas of software,
hardware, and formal foundations for transactional computing. Specific
topics of interest include but are not limited to:
* Run-time systems
* Hardware support
* Applications, workloads, and test suites
* Experience reports
* Language mechanisms and semantics
* Formal semantics
* Memory models
* Transactions for non-uniform and non-cache coherent memory systems
(e.g., NUMA, GPUs, RDMA, distributed transactions)
* Formal verification
* Speculative concurrency
* Conflict detection and contention management
* Debugging and tools
* Static analysis and compiler optimizations
* Checkpointing and failure atomicity
* Persistence and I/O
* Machine Learning and Transactional Memory
* Nesting and exceptions
* Impossibility results and lower bounds
* Concurrent data structures and algorithms
Papers should present original research. The final version of the
accepted papers will appear on the workshop's web site. These papers
will be available to the participants in electronic format during the
workshop. Transact/WTTM does not publish proceedings, so accepted papers
may appear in other venues as well. As transactional memory spans many
disciplines, papers should provide sufficient background material to
make them accessible to the broader community. Papers focused on
foundations should indicate how the work can be used to advance
practice; papers on experiences and applications should indicate how the
experiments reinforce or reflect principles.
** Submissions **
Please use EasyChair
(https://easychair.org/conferences/?conf=transact2017) to submit a paper
to TRANSACT!.
Papers must be submitted in PDF, and be no more than 8 pages in standard
two-column SIGPLAN conference format including figures and tables but
not including references. Shorter submissions are welcome. The
submissions will be judged based on the merit of the ideas rather than
the length. Submissions must be made through the on-line submission
site. Final papers will be available to participants electronically at
the meeting, but to facilitate resubmission to more formal venues, no
archival proceedings will be published, and papers will not be sent to
the ACM Digital Library.
Authors will have the option of having their final paper accessible from
the workshop website. Authors must be familiar with and abide by
SIGPLAN's republication policy, which forbids simultaneous submission to
multiple venues and requires disclosing prior publication of closely
related work.
At the discretion of the program committee and with the consent of the
authors, particularly worthy papers may be recommended for a special
journal issue.
Additional information (e.g., templates for papers’ submission) can be
found at the workshop’s webpage:
For any additional information, do not hesitate to contact the PC Co-Chairs:
Aleksandar Dragojevic, aleksandar.dragojevic at gmail.com
Idit Keidar, idish at ee.technion.ac.il
** Important Dates **
Submission Deadline: December 9, 2016
Author Notification: January 19, 2017
More information about the hpc-announce
