[hpc-announce] 2nd EAI International Conference on Cloud, Networking for IoT systems (CN4IoT 2016)
Massimo Villari mvillari at unime.it
Wed Mar 9 08:05:40 CST 2016
Call for Paper
SEPTEMBER 14-16, 2016
BRINDISI, ITALY
http://cloudniot.org/2016/show/home
Scope
The mission of International Conference on Cloud, Networking for IoT systems (CN4IoT) is to serve and promote ongoing re-search activities on the uniform management and operation related to software defined infrastructures. It aims to analyze limits and/or advantages in the exploitation of CN4IoT existing solutions developed for Cloud, Networking and IoT, and to present origi-nal and innovative contributions, where the explicit effort in at least two of the three main research fields introduces benefits and advantages clearly proven. Advances in ICT are changing the way we live and interact with each other, making our daily activ-ities fast, easier and more reliable. People use multiple devices at once and keep their mobile devices nearby. Often, such de-vices have built-in sensors that measure motion, orientation, and environmental conditions, providing raw data with high preci-sion and accuracy useful to monitor changes in the environment.
The physical world detected by sensors in our mobile and smart devices can be represented through objects (things). Each thing is uniquely identified, exposes specific capability for sensing, processing or actuation, and is interconnected to other things and systems through the Internet (Internet of Things - IoT). In this context, information travels along heterogeneous systems and net-works, leading to the movement of huge amounts of data (Big Data), which need to be annotated, stored, processed, integrated, and presented in a seamless, efficient and easily interpretable form.
On the other hand, cloud computing is a widely used technology that offers many benefits to both end users and business com-panies. It is able to provide theoretically unlimited computing and storage capabilities, and efficient communication services for transferring terabyte flows between data centres in an easy way. All these features make cloud computing a promising choice for supporting IoT services and applications. The integration of IoT devices with cloud computing systems is raising the interest of both the academic and industrial communities. Developments in this area pave the way to novel scenarios for IoT applications. Indeed, virtualisation techniques make pools of (virtual) sensors and actuators available as new types of on-demand resources over the Cloud, that can be integrated with other resources and exposed as cloud-based services.
IoT can significantly benefit from the integration with cloud computing and network infrastructures along with services provided by both big players (e.g., Microsoft, Google, Apple, and Amazon) and small and medium enterprises. Indeed, networking technol-ogies implement both virtual and physical interconnections among cooperating entities and Datacenters, organizing them into a unique computing ecosystem. In such a connected ecosystem, IoT applications can establish elastic relationship driven by per-formance requirements (e.g. information availability, execution time, monetary budget, etc.) and constraints (e.g. input data size, input data streaming rate, number of end-users connecting to that application, output data size, etc.). Thus, networking solutions specifically designed for the exploitation of Cloud services in IoT scenarios assume a crucial role. They allow developers to dif-ferentiate circuits aimed at IoT interactions, to increase Cloud scalability and efficiency in service provisioning, and to have both these advantages combined together. In many cases IoT can be seen as personal IoT, where the connection with the Internet is discontinuous, hence local caching facilities are required. The physical analytics can help the discovering of resources and ser-vices in applications use case characterized from Small Data. This data collected remotely can be further computated and feeding the Big Data seen in the hybrid model. The integration of IoT, Networking and Cloud computing can leverage the rising of new mash-up applications and services inter-acting with a multi-cloud ecosystem, where several cloud providers are interconnected through the network to deliver a univer-sal decentralized computing environment to support IoT scenarios. In order to achieve such next generation IoT applications, one of the major aspects that has to be considered is the networking. In fact, IoT mash-up applications interacting with Cloud systems require the proper setup of traditional (Intranet and Internet), proximal, and location-sensitive networks.
Potential topics of interest, which can be investigated from different perspectives (social, organizational, technological) include, but are not limited to, the following application domains:
ï	Deployment and autonomic management of densely interconnected and decentralised cloud infrastructures, including the extension of the fog computing paradigm to the edge of the network.
ï	Autonomic Management of Cloud networking in the context of software-defined data centres.
ï	Re-allocation of resources and services (independently of their location) across distributed computing and geographically separated data storage infrastructures
ï	Distributed cloud wireless networking
ï	Software Defined Infrastructure Architectures, Application Programming Interfaces Protocols & Programming languages
ï	Efficient Network and Cloud Function Virtualization (NFV)
ï	Service & Information Orchestration/Chaining and Life Cycle Management
ï	Energy Efficient and Green Software-defined Infrastructures
ï	Software-based Integration of Computing, Storage & Networks
ï	Software-Defined Datacenters and Inter-datacenter Networks
ï	Object identity management, discovery services in IoT,
ï	Virtualisation of objects, devices and IoT infrastructures
ï	Ad-hoc Cloud services, Big Data Analytics
ï	Interconnected smart objects and service infrastructures
ï	Infrastructures, platforms, and software for CN4IoT scenarios
ï	Software engineering methodology for the design of CN4IoTsystems
ï	Dynamic orchestration of cloud resources for IoT systems and applications
ï	Service discovery in CN4IoT- device Discovery, Data Discovery, service Discovery.
ï	Traffic Engineering and Quality of Service (QoS) in CN4IoT
ï	SLA Management for CN4IoT
ï	Monitoring of CN4IoT Systems
ï	Mobility support in CN4IoT
ï	Security and privacy preservation in CN4IoT Systems
ï	Building Trust-based communication and computing systems for IoT applications
ï	HPC-Cloud Platforms for IoT Big Data Analytics
ï	CN4IoT services (Sensing as a Service, Data Analytics as a Service, etc)
ï	Utility Models for CN4IoT metering
ï	IoT Microservices, Networking and CloudLet computing
ï	Communication challenges in CloudLet computing
ï	Software-defined networking support for IoT device fleets (M2M applications)
ï	Industrial IoT interacting with Clouds and Virtual Networks
ï	Personal IoT and Physical Analytics in IoT Focusing on Applications Use Case with Small Data
ï	Hybrid Sensor/Cloud networking
ï	SDN Switch/Router Architectures/Designs for CN4IoT
ï	Control Architectures/Network Programmability in CN4IoT
ï	Verification/Debugging/ Auditing Tools CN4IoT
ï	Energy-aware and sustainable computing solutions for CN4IoT applications
ï	Economics assessments aimed at Clouds, Data, IoT, Networking and Social in Hybrid Scenarios.
ï	Applications for Smart Cities, BigData Applications, ICT devices used in Factory of the Future, HPC, eHealth, Industrial Pro-cesses, Energy Efficiency Systems, Social Platforms, etc.
Highlights
ï	The event is endorsed by the European Alliance for Innovation, a leading community-based organisation devoted to the ad-vancement of innovation in the field of ICT.
ï	All accepted papers will be published by Springer and made available through SpringerLink Digital Library, one of the world's largest scientific libraries.
ï	Proceedings are submitted for inclusion to the leading indexing services: Elsevier (EI), Thomson Scientific (ISI), Scopus, Cross-ref, Google Scholar, DBLP.
ï	Best Papers will be considered for publication in the EAI Endorsed Transactions on Smart Cities.
Co-location of the Event
The event is co-located with the 2nd EAI International Conference on ICT Infrastructures and Services for Smart Cities (IISSC).
Paper Submission
Regular papers should be no more than 10 pages in length. Complete formatting and submission instructions can be found on the conference website.
Submissions will be reviewed anonymously by at least three expert reviewers.
Papers will be judged on originality, correctness, clarity and relevance.
Submission of the paper implies agreement of the author(s) to attend the conference and present the paper if accepted.
We reserve the right to exclude papers accepted but not presented from the conference proceedings submitted for archiv-ing and indexing.
Full details of submission procedures are available here: http://cloudniot.org/2016/show/initial-submission.
Publication
All presented papers in the conference will be published in the proceedings of the conference.
The authors of the best papers will be invited to submit an extended version of their work through one of the following EAI endorsed publications: EAI Endorsed Transactions on Smart Cities
Accepted papers will be published in the CN4IoT Conference Proceedings and by Springer-Verlag in the Lecture Notes of ICST (LNICST). The proceedings will be available both in book form and via the SpringerLink digital library, which is one of the largest digital libraries online and covers a variety of scientific disciplines.
The proceedings are submitted for inclusion to the leading indexing services: Elsevier (EI), Thomson Scientific (ISI), Scopus, Crossref, Google Scholar, DBLP.
IMPORTANT DATES
Full Paper Submission Deadline
22nd April 2016
Notification Deadline
27th May 2016
Camera-ready Deadline
24th June 2016
Start of the Conference
14th September 2016
End of the Conference
16th September 2016
ORGANIZING COMMITTEE
General Chair
Massimo Villari, University of Messina, Messina, Italy
Technical Program Committee Chair
Omer Rana, Cardiff University, UK
Rajiv Ranjan, Newcastle University, UK
Dario Bruneo, University of Messina, Messina, Italy
Publicity & Social Media Chair
Luca Foschini, Bologna University, Italy
Workshops Chair
Maurizio Giacobbe, University of Messina, Messina, Italy
Sponsorship & Exhibits Chair
Publications Chair
Maria Fazio, University of Messina, Messina, Italy
Philippe Massonet, CETIC, Charleroi, Belgium
Website Chair
Antonio Celesti, University of Messina, Messina, Italy
Local Chair
Antonella Longo, University of Salento, Italy
Conference Manager
Monika MajernÌkov·, European Alliance for Innovation, Bratislava, Slovakia
STEERING COMMITTEE
Chair
Imrich Chlamtac, Create-Net, Trento, Italy
Members
  Burak Kantarci, Clarkson University, NY, USA
  Georgianna Copil, TU Vienna, Austria
  Schahram Dustdar, TU Vienna, Austria
  Prem Prakash Jayaraman, CSIRO, Digital Productivity Flagship, Australia
  Rajiv Ranjan, CSIRO, Digital Productivity Flagship, Australia
  Joe Weinman, Chief IEEE Intercloud Testbed, Telx, NY, USA
  Frank Leymann, IASS, Stuttgart University, Germany
Paper submission
Papers should be submitted through EAI 'Confy' system at Confy, and have to comply with the SPRINGER format (see Author's kit section).
How do I submit a paper in Confy?
1.	Go to Confy website
2.	Login or sign up as new user
3.	Scroll the list of conferences open for submission
4.	Select CN4IoT 2016
5.	Click the 'submit a paper' link and follow the instructions
Submission guidelines
ï	Papers should be in English.
ï	Regular papers should be up to 10 pages in length.
ï	Previously published work may not be submitted, nor may the work be concurrently submitted to any other conference or journal. Such papers will be rejected without review.
ï	The paper submissions must follow the SPRINGER formatting guidelines (see Author's kit section).
ï	Read the Publication Ethics and Malpractice Statement.
Instructions and Templates
Papers must be formatted using the SPRINGER Author's Kit. Detailed instructions and templates are available.
Publication Ethics and Malpractice statement
EAI conferences are committed to upholding the highest standards of publication ethic and publication malpractices. All this Publication Ethics and Malpractice Statement is based, in large part, on the COPE (Committee on Publication Ethics).
Prof. Eng. Massimo Villari, PhD
Dip. di Ingegneria
Universita' di Messina
C.Da Di Dio, N°1 - 98166 - Messina
- ITALY -
phone: +39 090 397 7342
email: mvillari at unime.it
http://it.linkedin.com/in/mvillari <http://it.linkedin.com/in/mvillari>
URL: <https://lists.mcs.anl.gov/mailman/private/hpc-announce/attachments/20160309/7205b84a/attachment-0001.html>
More information about the hpc-announce mailing list
