[hpc-announce] Sca/LAPACK, PLASMA, & MAGMA software survey
Jack Dongarra
dongarra at icl.utk.edu
Mon Jan 11 10:55:40 CST 2016
We would like you opinion and provide input on dense linear algebra software packages that you use, in particular our libraries LAPACK, ScaLAPACK, PLASMA and MAGMA. The purpose of this survey is to improve these libraries to benefit you, the users. There are many possible improvements that could be made, and this survey will help us prioritize them.
The survey has six parts and it’s easy to skip a part if it’s not relevant.
1. A general section about your applications and their needs.
2. Specific questions about your LAPACK uses, if any.
3. Specific questions about your ScaLAPACK uses, if any.
4. Specific questions about your PLASMA uses, if any.
5. Specific questions about your MAGMA uses, if any.
6. An open section for any additional comment
We estimate that it should take 10 minutes to fill out the survey.
You will find the survey here:
https://www.surveymonkey.com/r/2016DenseLinearAlgebra <https://www.surveymonkey.com/r/2016DenseLinearAlgebra>
Thank you very much.
The LAPACK Team
Prof. Jack Dongarra; Innovative Computing Laboratory; EECS Department;
1122 Volunteer Blvd; University of Tennessee; Knoxville TN 37996-3450;
+1-865-974-8295; dongarra at eecs.utk.edu; http://www.cs.utk.edu/~dongarra/
URL: <https://lists.mcs.anl.gov/mailman/private/hpc-announce/attachments/20160111/30d10e6e/attachment.html>
More information about the hpc-announce
