[hpc-announce] CALL FOR SCALE CHALLENGE PROPOSALS
Antonio J. Peña
antonio.pena at bsc.es
Mon Dec 19 10:46:39 CST 2016
*** CALL FOR SCALE CHALLENGE PROPOSALS ***
The 10th IEEE International Scalable Computing Challenge (SCALE 2017)
Co-located with
The 17th IEEE/ACM International Symposium on Cluster, Cloud and Grid
Computing (CCGrid 2017)
May 14-17, 2017 Madrid, Spain
URL: https://www.arcos.inf.uc3m.es/wp/ccgrid2017/calls/scale-challenge/
*** OBJECTIVE AND FOCUS ***
The objective of the 10th IEEE International Scalable Computing
Challenge (SCALE 2017) is to highlight and showcase real-world problem
solving using computing that scales. Effective solutions to many
scientific and engineering problems require applications that can scale.
There are different dimensions to application scalability. For example,
applications can scale-up to a large number of cores on a compute unit,
scale-out to utilize multiple distinct compute units, or exhibit elastic
scaling to acquire and release resources on-demand, based on current
need. The result may be an application that can solve a larger problem,
increase throughput, and/or reduce execution time. In order to scale,
applications need to be supported by tools, middleware, software
cyber-infrastructure, programming frameworks, computing infrastructure,
etc. The SCALE Challenge is concerned with advances in application
development and their supporting infrastructure to enable scaling. All
papers presented at the SCALE challenge of IEEE/ACM CCGrid 2017 will be
submitted to IEEE Xplore for publication and EI indexing.
*** SUBMISSION LINK ***
https://www.easychair.org/conferences/?conf=ccgrid2017
**** CALL FOR PROPOSALS ****
contest focuses on end-to-end problem solving using concepts,
technologies and architectures (including Clusters, Grids and Clouds)
that facilitate scaling. Participants in the challenge will be expected
to identify significant current real-world problems where scalable
computing techniques can be effectively used, and design, implement,
evaluate, and demonstrate solutions. SCALE 2017 will be held in
conjunction with the 17th CCGrid Conference in Madrid.
We invite teams to submit papers outlining the problem addressed and the
technologies employed to enable applications to scale. Papers should be
up to 6 pages long in standard IEEE format. In addition to listing the
team members and contact information, the papers should clearly outline:
An overview of the problem being solved and the techniques employed
The application scenario and its requirements
Performance metrics (number of cores, computational throughput, I/O
bandwidth, metadata operations, etc.), supporting data, and a
qualitative description of how the application scales – scale-up,
scale-out or any other type of scaling
The solution – architecture, underlying concepts and technologies
used, highlighting the innovative aspects of the solution
Impact of the solution, including its extensibility, the uniqueness
of the solutions and the results, and the extent to which the
presented solution pushes the envelope in scalable computing
Analysis of the solution and technology employed with a comparison
to related approaches
Papers will be shortlisted using the above 6 points as merit criteria,
and up to 4 papers will be invited to compete in the final round at
CCGrid 2017. Finalists will be judged on the quality of their
presentation, which shall include a short demonstration, as well as
their responses to questions by a technical committee. At least one
member from each selected team is expected to register, present the work
in a special session at the CCGrid 2017 conference, and demonstrate the
scale component. The judges will select a first prize winner at the
conference. Finalist papers will appear in the proceedings of the CCGrid
2017 Conference.
Participation from students and young researchers, especially in
leadership roles, is strongly encouraged.
**** AWARDS ****
The finalists will be judged on the quality of their presentation and
demonstration, as well as their responses to questions by a technical
committee, and a first price will be awarded.
**** IMPORTANT DATES ****
Abstract submission: January 31st, 2017 Deadline for submitting
proposals: *February 8th, 2017*
**** SCALE CHALLENGE 2017 CHAIRS ****
Michela Taufer, University of Delaware, USA
Antonio J. Peña, Barcelona Supercomputing Center, Spain
Antonio J. Peña, PhD
Senior Researcher, Computer Sciences Department
Manager, BSC/UPC NVIDIA GPU Center of Excellence
https://www.bsc.es/pena-antonio
WARNING / LEGAL TEXT: This message is intended only for the use of the
individual or entity to which it is addressed and may contain
information which is privileged, confidential, proprietary, or exempt
from disclosure under applicable law. If you are not the intended
recipient or the person responsible for delivering the message to the
intended recipient, you are strictly prohibited from disclosing,
distributing, copying, or in any way using this message. If you have
received this communication in error, please notify the sender and
destroy and delete any copies you may have received.
http://www.bsc.es/disclaimer
URL: <https://lists.mcs.anl.gov/mailman/private/hpc-announce/attachments/20161219/0468e095/attachment.html>
More information about the hpc-announce
