[hpc-announce] HiPMoS 2015 - HIGH PERFORMANCE MODELLING AND SIMULATION 2015
Ciprian Dobre
ciprian.dobre at cs.pub.ro
Tue Nov 18 02:03:23 CST 2014
HiPMoS 2015
https://www.dem.unina2.it/hipmos/
CALL FOR PAPERS
We have the great pleasure to invite you to participate in the High
Performance Modeling and Simulation 2015 track, that will be held in the
framework of the 29th European Conference on Modelling and Simulation (ECMS
2015) in May 26th - 29th, 2015, Varna, Bulgaria. All ECMS papers are indexed
by SCOPUS, DBLP, ISI, INSPEC and DOI.
SCOPE
Modeling and simulation are widely considered essential tools in many areas
of science and engineering for the prediction and analysis of complex
systems and natural phenomena. They often require a significant amount of
computational resources with data sets typically scattered across different
geographical locations.
Furthermore, the development of such complex modelling and simulation
environments usually requires collaborative efforts from researchers with
different domain knowledge and expertise, possibly at different locations.
High performance computing is arguably required to deal with the behaviour
and complexity of such large-scale systems.
ORGANIZATION AND TOPICS
HiPMoS 2015 is organized as a multi-session track and is composed of the
following events:
** Special Session on "Modelling and Simulation of Data Intensive Systems
(HiPMoS -DIS)"**
In today's data intensive computing, the application developers need
abstract simulation models to expose expected hardware features (e.g., SIMD,
lightweight cores, or specialized functional units) and performance targets
in terms of hierarchical parallelism, scale, data movement, computational
intensity, bandwidths, latencies, and storage capacities of possible data
intensive applications and systems, as well as non-performance objectives
such as power and resilience. System architects need
architecture-independent models of important applications that they can use
to identify, understand, and evaluate application behavior on these proposed
architectures. These abstractions must exist across the modeling,
simulation, and measurement infrastructures.
Modeling and simulation techniques must provide predictive and optimization
capabilities at runtime. This will require the development of rapid
evaluation techniques as well as interfaces for incorporating models into
the layers within the software stack. In addition to dynamic model creation,
models must be actionable. That is, the models must enable appropriate
levels of the software stack to react to the instantaneous state of the
system, both hardware and software, and provide the necessary information
that can be used to guide and optimize system operation.
Topics of interest for this session include but are not limited to the
following:
- Infrastructures and middleware as enablers for modelling and simulation of
data intensive systems
- Evaluation of programming models supporting data intensive applications
- Runtime systems supporting modelling of data intensive applications
- Productivity tools for data intensive applications
- Development and generation of machine and application abstractions for
- Dynamic and actionable modeling of data intensive systems
- Standards, integration and interoperability of modelling and simulation
methodologies and tools for data intensive computing
** Special Session on "Probability and statistical methods for modelling and
simulation of high performance information systems (HiPMoS- ProbStat)" **
The development trends of modern information technologies lead to the
constant growth of complexity of information systems and call for their high
performance. Stochastic nature of flows that information systems need to
serve and presence of stochastic internal processes that influence their
behavior justifies the use of probabilistic modeling and simulation when one
needs to analyze their performance. Despite increasing complexity obvious
requirement for system's high performance which ensures, for example, low
response times and accuracy, remains unchanged and it calls for advanced
methods of modeling and simulation. Such methods must not be limited to
those which ensure fast computations but include also those which provide
new suitable (from the point of view of high performance) approaches for
representation and analysis of system's component and system as a whole.
The topics of this session are focused on but not limited to the following:
- Queuing Systems Modelling and Simulation
- Performance Modelling and Analysis of Information and Telecommunication
Networks
- Information Flows Modeling and Analysis
- Overload and Flow Control Modelling and Simulations
- Assessment of efficiency, reliability and stability (tolerance) of high
SUBMISSION GUIDELINES
Authors are invited to submit research and application papers following the
IEEE Computer Society Proceedings Manuscripts style available at the main
conference web page
(http://www.scs-europe.net/conf/ecms2015/authorkit.html).
We solicit the submission of academic conference papers (7 pages)
representing original, previously unpublished work. Submitted papers will be
carefully evaluated based on originality, significance, technical soundness,
and clarity of exposition. Papers should be prepared as PDF files and
submitted electronically to the ECMS 2015 online submission system.
Submission of the paper implies that should the paper be accepted, at least
one of the authors must register and present the paper at the conference.
Accepted papers will be given guidelines in preparing and submitting the
final manuscript(s) together with the notification of acceptance. HiPMoS
2015 papers must be submitted for the selected HiPMoS session.
The authors must select the following options for BOTH SUBMISSION and
REGISTRATION:
DIS for "Modelling and Simulation of Data Intensive Systems" special session
PROBSTAT for "Probability and statistical methods for modelling and
simulation of high performance information systems " special session.
For more detailed information contact the HiPMOS track organizers or visit:
http://www.dem.unina2.it/hipmos/, the HiPMoS 2015 webpage
http://www.scs-europe.net/conf/ecms2015/, the ECMS 2015 webpage
IMPORTANT DATES
Paper Submissions: February 13, 2015
Notification of Acceptance: March 13, 2015
Camera-Ready/Registration: April 15, 2015
Conference Dates: May 26 - 29, 2015
COMMITTEES
** HiPMoS 2015 **
CHAIR
Mauro Iacono, Seconda Universitŕ degli Studi di Napoli, Italy
CO-CHAIR
Marco Gribaudo, Politecnico di Milano, Italy
HONORARY CHAIR
Joanna Kolodziej, Cracow University of Technology, Cracow, Poland
** HiPMoS DIS session **
CHAIR
CO-CHAIR
PROGRAM COMMITTEE
Piotr Arabas, Warsaw University of Technology and NASK, Poland
Enrico Barbierato, Seconda Universitŕ degli Studi di Napoli, Italy
Nik Bessis, University of Derby, United Kingdom
Aleksander Byrski, AGH University of Science and Technology, Poland
Valentin Cristea, University Politehnica of Bucharest, Romania
Gregoire Danoy, University of Luxembourg, Luxembourg
Roman Debski, AGH University of Science and Technology, Poland
Ciprian Dobre, University Politehnica of Bucharest, Romania
Daniel Grzonka, Cracow University of Technology, Poland
Catalin Leordeanu. University Politehnica of Bucharest, Romania
Alexander H. Levis, George Mason University, USA
Michal Marks, Research and Academic Computer Network NASK, Poland
Stefano Marrone, Seconda Universitŕ degli Studi di Napoli, Italy
Djamel Eddine Saidouni, MISC Laboratory, University Constantine 2, Algeria
Ewa Niewiadomska-Szynkiewicz, Warsaw University of Technology and NASK,
Poland
Magdalena Szmajduch, Cracow Univ. of Technology, Poland
Florin Pop, University Politehnica of Bucharest, Romania
Stelios Sotiriadis,Technical University of Crete, Greece
Jie Tao, Steinbuch Centre for Computing, Karlsruhe Institute of Technology,
Germany
Armin Zimmermann, TU Ilmenau, Germany
** HiPMoS ProbStat session **
CHAIRS
Alexander I. Zeifman, Vologda State University, Russia
Pavel O. Abaev, Peoples' Friendship University of Russia, Russia
Rostislav V. Razumchik, Institute of Informatics Problems - Russian Academy
of Sciences, Peoples' Friendship University of Russia, Russia
PROGRAM COMMITTEE
Alexander A. Grusho Institute of Informatics Problems - Russian Academy of
Sciences, Russia
Victor Yu. Korolev, Lomonosov Moscow State University, Russia
Alexander V. Pechinkin, Institute of Informatics Problems, Russian Academy
of Sciences, Russia
Konstantin E. Samouylov, Peoples' Friendship University of Russia, Russia
Sergey Ya. Shorgin, Institute of Informatics Problems, Russian Academy of
Sciences, Russia
URL: <https://lists.mcs.anl.gov/mailman/private/hpc-announce/attachments/20141118/f49ca376/attachment-0001.html>
Type: application/pdf
Desc: not available
URL: <https://lists.mcs.anl.gov/mailman/private/hpc-announce/attachments/20141118/f49ca376/attachment-0001.pdf>
More information about the hpc-announce
