[hpc-announce] CFP: MULTIPROG7 at Hipeac 2014
Osman Unsal osman.unsal at bsc.es
Fri Oct 4 14:57:11 CDT 2013
CALL FOR PAPERS
Seventh Workshop on Programmability Issues for Heterogeneous Multicores
(MULTIPROG-2014)
Submission Deadline: October 18, 2013
Held in conjunction with the 9th International Conference on High-Performance
and Embedded Architectures and Compilers (HiPEAC)
Vienna, Austria, January 22, 2014
Workshop website:http://multiprog.ac.upc.edu/
Goal of the Workshop
Computer manufacturers have already embarked on the multi-core roadmap, promising to add
more and more cores/hardware threads on a chip: many-cores are on the horizon. This shift
to an increasing number of cores and heterogeneous architectures has placed new burdens
on the programming community. Until now, software has been developed with a single
processor in mind and it needs to be parallelized and optimized for accelerators such
as GPUs to take advantage of the new breed of multi-/many-core computers. As a result,
progress in how to easily harness the computing power of multi-core architectures is in
great demand.
The seventh edition of the MULTIPROG workshop aims to bring together, and cause fruitful
interaction between, researchers interested in programming models and their implementation
and in computer architecture, with special emphases on heterogeneous architectures. A wide
spectrum of issues are central themes for this workshop such as what the future programming
models should look like to accelerate software productivity, how compilers, run-times and
architectures should support these new programming models, innovative algorithm and data
structure development, and heterogeneous embedded, accelerated systems.
MULTIPROG is intended for quick publication of early results, work-in-progress, etc, and
is not intended to prevent later publication of extended papers. We will prioritize papers
addressing cross-cutting issues and that provide thought-provoking insights into the main
themes. Informal proceedings with accepted papers will be made available at the workshop.
Topics of interest
Papers are sought on topics including, but not limited to:
      * Multi-core architectures
            o Architectural support for compilers/programming models
	   o Processor (core) architecture and accelerators, in particular GPUs
            o Memory system architecture
            o Performance, power, temperature, and reliability issues
      * Heterogeneous computing
	  o Algorithms and data structures for heterogeneous systems
	  o Applications for heterogeneous computing and real-time graphics
      * Programming models for multi-core architectures
            o Language extensions
            o Run-time systems
            o Compiler optimizations and techniques
            o Tools for discovering and understanding parallelism
      * Benchmarking of multi-/many-core architectures
            o Tools for understanding performance and debugging
	   o Case studies and performance evaluation
Organizers
Eduard Ayguade UPC and Barcelona Supercomputing Center Spain (eduard[at]ac.upc.edu)
Benedict R. Gaster Qualcomm USA (bgaster[at]qti.qualcomm.com)
Lee Howes Qualcomm USA (lhowes[at]qti.qualcomm.com)
Per Stenstrom Chalmers University of Technology Sweden (pers[at]chalmers.se)
Osman S. Unsal BSC-Microsoft Research Centre Spain (osman.unsal[at]bsc.es)
Important dates
Submission: October 18, 2013
Notification: November 26, 2013
Paper submission
Submitted papers should use the LNCS format and should be 12 pages maximum. Manuscript
preparation guidelines can be found at the LNCS web site. Please check that (i) pages are
numbered, and (ii) graphs etc. remain legible when printed in black and white.
Submit your paper here:http://multiprog.ac.upc.edu/hotcrp14
Program committee
Mats Brorsson KTH Sweden
Pascal Felber U. of Neuchatel Switzerland
Roberto Giorgi U. of Siena Italy
Hakan Grahn Blekinge Institute of Technology Sweden
Tim Harris Oracle UK
Paul Kelly Imperial College of London UK
Mikel Lujan U. of Manchester UK
Tim Mattson Intel Research USA
Simon McIntosh-Smith U. of Bristol UK
Avi Mendelson Technion Israel
Dimitris Nikolopoulos Queens U. UK
Andy Pimentel U. of Amsterdam Netherlands
Oscar Plata U. of Malaga Spain
Yanos Sazeides U. of Cyprus Cyprus
David Black-Schaffer Uppsala U. Sweden
Nir Shavit MIT USA
Dongping Zhang AMD USA
WARNING / LEGAL TEXT: This message is intended only for the use of the
individual or entity to which it is addressed and may contain
information which is privileged, confidential, proprietary, or exempt
from disclosure under applicable law. If you are not the intended
recipient or the person responsible for delivering the message to the
intended recipient, you are strictly prohibited from disclosing,
distributing, copying, or in any way using this message. If you have
received this communication in error, please notify the sender and
destroy and delete any copies you may have received.
http://www.bsc.es/disclaimer
More information about the hpc-announce mailing list
