[hpc-announce] RAW 2014 CFP
Weirong Jiang
weirongj at acm.org
Thu Aug 15 15:35:39 CDT 2013
Could you please post the following CFP to the list? Thanks.
[Please accept our apologies if you receive multiple copies of this Call
for Papers (CFP).]
CALL FOR PAPERS
21st Reconfigurable Architectures Workshop
May 18-19, 2014, Phoenix, USA
Submission deadline: December 9, 2013
http://www.ece.lsu.edu/vaidy/raw/
The 21st Reconfigurable Architectures Workshop (RAW 2014) will be held in
Phoenix, USA in May 2014. RAW 2014 is associated with the 28th Annual
International Parallel & Distributed Processing Symposium (IPDPS 2014) and
is sponsored by the IEEE Computer Society Technical Committee on Parallel
Processing. The workshop is one of the major meetings for researchers to
present ideas, results, and on-going research on both theoretical and
practical advances in Reconfigurable Computing.
A reconfigurable computing environment is characterized by the ability of
underlying hardware architectures or devices to rapidly alter (often on the
fly) the functionalities of their components and the interconnection
between them to suit the problem at hand. The area has a rich theoretical
tradition and wide practical applicability. There are several commercially
available reconfigurable platforms (FPGAs and coarse-grained devices) and
many modern applications (including embedded systems and HPC) use
reconfigurable subsystems. An appropriate mix of theoretical foundations
and practical considerations, including algorithms architectures,
applications, technologies and tools, is essential to fully exploit the
possibilities offered by reconfigurable computing. The Reconfigurable
Architectures Workshop aims to provide a forum for creative and productive
interaction for researchers and practitioners in the area.
The PDF file of the CFP is attached.
Weirong Jiang
Xilinx Research Labs
San Jose, CA 95124
URL: <https://lists.mcs.anl.gov/mailman/private/hpc-announce/attachments/20130815/108b79b4/attachment-0001.html>
Type: application/pdf
Desc: not available
URL: <https://lists.mcs.anl.gov/mailman/private/hpc-announce/attachments/20130815/108b79b4/attachment-0001.pdf>
More information about the hpc-announce
