[ExM Users] mkstatic questions
Ketan Maheshwari ketan at mcs.anl.gov
Fri May 30 11:33:48 CDT 2014
I rebuilt the application recently without MPI. It seems to be working
outside of Swift on Cetus compute nodes.
On Fri, May 30, 2014 at 11:18 AM, Tim Armstrong <tim.g.armstrong at gmail.com>
wrote:
>  Regarding the MPI error - that seems strange.  There are multiple places
> in the code that it might be.
>  One possible cause is if something funny happened in compiling/linking -
> e.g. multiple compilers or versions of things linked together.  Have you
> tried running the code locally?
> I'm a little perplexed because MPI tag 4 shouldn't be used in your
> application - the message type (Iget) is only really used for
> gemtc/coasters applications.  It would be helpful to debug further if I
> could get a log from the run with ADLB debugging enabled at compile time
> (--enable-log-debug for the ADLB configure stage, or setting EXM_DEBUG=1 in
> exm-settings.sh depending on how you built it).
>  - Tim
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140530/47fc192d/attachment.html>
More information about the ExM-user mailing list
