[ExM Users] mkstatic questions
Tim Armstrong tim.g.armstrong at gmail.com
Fri May 30 11:18:32 CDT 2014
Regarding the MPI error - that seems strange.  There are multiple places in
the code that it might be.
One possible cause is if something funny happened in compiling/linking -
e.g. multiple compilers or versions of things linked together.  Have you
tried running the code locally?
I'm a little perplexed because MPI tag 4 shouldn't be used in your
application - the message type (Iget) is only really used for
gemtc/coasters applications.  It would be helpful to debug further if I
could get a log from the run with ADLB debugging enabled at compile time
(--enable-log-debug for the ADLB configure stage, or setting EXM_DEBUG=1 in
exm-settings.sh depending on how you built it).
- Tim
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140530/f9cff5a9/attachment.html>
More information about the ExM-user mailing list
