[ExM Users] turbine-aprun-run doesn't create directory
    Tim Armstrong
    tim.g.armstrong at gmail.com
    Mon Jun 30 14:19:27 CDT 2014
We don't really have documented behaviour here.  It does currently create
the output directory for stdout/stderr.  What is the actual behaviour at
runtime? Do you see a crash or anything?
- Tim
On Mon, Jun 30, 2014 at 1:54 PM, Ketan Maheshwari <ketan at mcs.anl.gov> wrote:
> The behavior in different when run with turbine command on MCS
> workstation. The "results" directory gets created as a result of running
> this script.
> On Mon, Jun 30, 2014 at 1:52 PM, Wozniak, Justin M. <wozniak at mcs.anl.gov>
> wrote:
>> Swift/T doesn't create or stage output files- it's up to the app to
>> create any desired output directories.  It does not interpret the output
>> file name.
>> On 06/30/2014 01:42 PM, Ketan Maheshwari wrote:
>> Hi,
>>  With the following line:
>>  file output<sprintf("results/cmdout%i%i.txt", i,j)> =
>> runcommand(command+" "+filename(afile));
>>  I expect turbine to create a directory "results", in the jobdir  in the
>> case of turbine-aprun-run.zsh, but it seems this is not created. Is this
>> expected behavior?
>>  The full script is:
>>  import files;
>> import io;
>> import string;
>> import python;
>>  app (file out) runcommand (string instr){
>>    "/bin/sh" "-c" instr @stdout=out;
>>  main{
>>     file files[] = glob("adir/*.txt");
>>     string commands[]=["head","tail","stat"];
>>      foreach afile, i in files{
>>         foreach command, j in commands{
>>  Thanks,
>> Ketan
>> ExM-user mailing listExM-user at lists.mcs.anl.govhttps://lists.mcs.anl.gov/mailman/listinfo/exm-user
>> Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140630/f340d3be/attachment-0001.html>
More information about the ExM-user
