[ExM Users] app fails
Justin M Wozniak
wozniak at mcs.anl.gov
Thu Jun 26 14:14:44 CDT 2014
bash -c requires one argument:
"/bin/bash" "-c" (acmd+" "+arg) @stdout=o
On 06/26/2014 02:07 PM, Ketan Maheshwari wrote:
> Thanks!
> On Thu, Jun 26, 2014 at 2:01 PM, Wozniak, Justin M.
> <wozniak at mcs.anl.gov <mailto:wozniak at mcs.anl.gov>> wrote:
> Use:
> "/bin/bash" "-c" acmd arg @stdout=o
> On 06/26/2014 01:53 PM, Ketan Maheshwari wrote:
>> Hi,
>> The following T script with app def fails for me:
>> import files;
>> import io;
>> import string;
>> app (file o) cmd (string acmd, string arg) {
>> "/bin/bash -c" acmd arg @stdout=o
>> main {
>> file output<sprintf("s.txt")> = cmd("echo", "hello");
>> CAUGHT ERROR:
>> external command failed: /bin/bash -c echo hello
>> while executing
>> "error $msg"
>> (procedure "turbine_error" line 6)
>> invoked from within
>> "turbine_error "external command failed: $cmd $args""
>> (procedure "turbine::exec_external" line 16)
>> invoked from within
>> "turbine::exec_external "/bin/bash -c" [ dict create "stdout"
>> ${v:__filename:o} ] ${v:acmd} ${v:arg}"
>> (procedure "cmd-app-leaf0" line 17)
>> invoked from within
>> "cmd-app-leaf0 0 {7.0} 1 {1} {4} {file 7 is_mapped 1}"
>> Turbine worker task error in: cmd-app-leaf0 0 {7.0} 1 {1} {4}
>> invoked from within
>> "c::worker_loop $WORK_TYPE(WORK)"
>> (procedure "worker" line 28)
>> invoked from within
>> "worker $rules $startup_cmd"
>> (procedure "enter_mode_unchecked" line 5)
>> invoked from within
>> "enter_mode_unchecked $rules $startup_cmd"
>> (procedure "enter_mode" line 10)
>> invoked from within
>> "enter_mode $rules $startup_cmd "
>> CALLING adlb::abort
>> ADLB_Abort(1)
>> MPI_Abort(1)
>> application called MPI_Abort(MPI_COMM_WORLD, 1) - process 1
>> I want to run an arbitrary command with arbitrary args via
>> /bin/bash or /bin/sh.
>> Any suggestions?
>> Thanks,
>> Ketan
>> ExM-user mailing list
>> ExM-user at lists.mcs.anl.gov <mailto:ExM-user at lists.mcs.anl.gov>
>> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
> Justin M Wozniak
Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140626/979b85ec/attachment-0001.html>
More information about the ExM-user
