[ExM Users] app fails
Ketan Maheshwari ketan at mcs.anl.gov
Thu Jun 26 14:07:46 CDT 2014
Thanks!
On Thu, Jun 26, 2014 at 2:01 PM, Wozniak, Justin M. <wozniak at mcs.anl.gov>
wrote:
> Use:
>  "/bin/bash"  "-c" acmd arg @stdout=o
> On 06/26/2014 01:53 PM, Ketan Maheshwari wrote:
> Hi,
>  The following T script with app def fails for me:
>  import files;
> import io;
> import string;
>  app (file o) cmd (string acmd, string arg) {
>   "/bin/bash -c" acmd arg @stdout=o
>  main {
> file output<sprintf("s.txt")> = cmd("echo", "hello");
>  CAUGHT ERROR:
> external command failed: /bin/bash -c echo hello
>     while executing
> "error $msg"
>      (procedure "turbine_error" line 6)
>     invoked from within
> "turbine_error "external command failed: $cmd $args""
>     (procedure "turbine::exec_external" line 16)
>     invoked from within
> "turbine::exec_external "/bin/bash -c" [ dict create "stdout"
> ${v:__filename:o} ] ${v:acmd} ${v:arg}"
>     (procedure "cmd-app-leaf0" line 17)
>     invoked from within
> "cmd-app-leaf0 0 {7.0} 1 {1} {4} {file 7 is_mapped 1}"
> Turbine worker task error in: cmd-app-leaf0 0 {7.0} 1 {1} {4} {file 7
> is_mapped 1}
>     invoked from within
> "c::worker_loop $WORK_TYPE(WORK)"
>     (procedure "worker" line 28)
>     invoked from within
> "worker $rules $startup_cmd"
>     (procedure "enter_mode_unchecked" line 5)
>     invoked from within
> "enter_mode_unchecked $rules $startup_cmd"
>     (procedure "enter_mode" line 10)
>     invoked from within
> "enter_mode $rules $startup_cmd "
> CALLING adlb::abort
> ADLB_Abort(1)
> MPI_Abort(1)
> application called MPI_Abort(MPI_COMM_WORLD, 1) - process 1
>  I want to run an arbitrary command with arbitrary args via /bin/bash or
> /bin/sh.
>  Any suggestions?
>  Thanks,
> Ketan
> ExM-user mailing listExM-user at lists.mcs.anl.govhttps://lists.mcs.anl.gov/mailman/listinfo/exm-user
> Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140626/e80098a5/attachment.html>
More information about the ExM-user mailing list
