[ExM Users] create directory based on loop index
Justin M Wozniak
wozniak at mcs.anl.gov
Wed Jul 30 10:39:33 CDT 2014
You will need to do this kind of thing in the task.
On 07/30/2014 10:34 AM, Ketan Maheshwari wrote:
> Thanks, create-dir has worked. I think I need a bit more than this: Is
> it possible to cd into this newly created dir and run the app. This is
> needed because the Rosetta invocation does not have a way to
> distinguish some of the outputs and will result in overwrites. The
> code is as follows:
> foreach pdb in PDB{
> foreach i in [0:9]{
> create_dir("dir"+fromint(i)) => leaf_main(["-database", "...",
> "..."]); //need to perform this operation inside diri
> Thanks,
> Ketan
> On Wed, Jul 30, 2014 at 10:04 AM, Tim Armstrong
> <tim.g.armstrong at gmail.com <mailto:tim.g.armstrong at gmail.com>> wrote:
> You'll also need to convert the loop index to a string with
> fromint(i) or sprintf("%i", i) or similar.
> It's probably better and less error-prone in general to ensure
> that any functions that create their output files also create the
> directory. App functions should already do this (if they don't,
> it's a bug).
> - Tim
> On Wed, Jul 30, 2014 at 9:52 AM, Justin M Wozniak
> <wozniak at mcs.anl.gov <mailto:wozniak at mcs.anl.gov>> wrote:
> Yes but do it like this:
> foreach i in [0:99]{
> create_dir("dir"+i) =>
> do_some_op(inargs, "dir"+i+"/"+outfile);
> On 07/30/2014 09:50 AM, Ketan Maheshwari wrote:
>> In T, is it possible to create directory on the fly within a
>> foreach loop like so:
>> create_dir("dir"+i);
>> Thanks,
>> Ketan
>> ExM-user mailing list
>> ExM-user at lists.mcs.anl.gov <mailto:ExM-user at lists.mcs.anl.gov>
>> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
> Justin M Wozniak
Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140730/1b2160fa/attachment-0001.html>
More information about the ExM-user
