[ExM Users] Submitting tasks on Raven
Michael Wilde wilde at mcs.anl.gov
Thu Apr 25 09:40:33 CDT 2013
Can someone help Scott with this?
Scott, I think #PBS -m is the email notification flag, not memory.
Its complaining that your aprun command is asking for more resources
than the qsub command requested for the job.
Check that the aprun -n -N -d do not exceed mppwidth etc from pns
Test your aprun args with a qsub -I asking for the correct numnber of
nodes and cores
On 4/24/13, Scott Krieder <skrieder at iit.edu> wrote:
> Hi All,
> I'm trying to run noop.tcl with turbine on Raven. I keep getting a memory
> error:
> apsched: claim exceeds reservation's memory
> I tried a few different values(100, 100M) for
> #PBS -m
> but I keep getting the error.
> Is there a way to let the PBS job take as much memory as it needs?
> Thanks,
> Scott
> =====aprun.sh script that I'm running=====
> # USAGE: qsub aprun.sh
> # The user should copy and edit the parameters throughout this script
> # marked USER:
> # USER: Directory available from compute nodes:
> USER_WORK=/ufs/home/users/p01684
> # USER: (optional) Change the qstat name
> #PBS -N turbine
> # USER: Set the job size
> #PBS -l mppwidth=1,mppnppn=3,mppdepth=1
> # USER: Set the wall time
> #PBS -l walltime=10:00
> # USER: (optional) Redirect output from its default location ($PWD)
> #PBS -o /ufs/home/users/p01684/pbs.out
> #PBS -j oe
> #PBS -m n
> # USER: Set configuration of Turbine processes
> export TURBINE_ENGINES=1
> export ADLB_SERVERS=1
> echo "Turbine: aprun.sh"
> date "+%m/%d/%Y %I:%M%p"
> echo
> # Be sure we are in an accessible directory
> cd $PBS_O_WORKDIR
> set -x
> # USER: Set Turbine installation path
> export TURBINE_HOME=${USER_WORK}/Public/sfw/turbine
> # USER: Select program name
> # PROGRAM=${USER_WORK}/adlb-data.tcl
> PROGRAM=${TURBINE_HOME}/test/noop.tcl
> source ${TURBINE_HOME}/scripts/turbine-config.sh
> if [[ ${?} != 0 ]]
> then
>   echo "turbine: configuration error!"
>   exit 1
> fi
> # Send environment variables to PBS job:
> #PBS -v TURBINE_ENGINES ADLB_SERVERS TURBINE_HOME
> # USER: Set aprun parameters to agree with PBS -l settings
> # aprun -n 1 -N 1 -cc none -d 1 ${TCLSH} ${PROGRAM}
> aprun -n 3 -N 3 -cc none -d 1 ${TURBINE_HOME}/bin/turbine ${PROGRAM}
> Scott J. Krieder
> C: 419-685-0410
> E: skrieder at iit.edu
> http://datasys.cs.iit.edu/~skrieder/
Sent from my mobile device
More information about the ExM-user mailing list
