[ExM Users] Multinode Swift on Raven
Justin M Wozniak
wozniak at mcs.anl.gov
Mon Apr 22 09:36:04 CDT 2013
I have not tried these doing this with Swift/T on a Cray yet. However,
it should not be too hard.
I assume you are using Turbine's provided aprun.sh script. You can also
use the new (as of last week) turbine-aprun-run script, which may be
easier to use. Documentation for the new script is here:
http://www.mcs.anl.gov/exm/local/guides/turbine-sites.html#_raven
In either case, you will need to edit the script and modify the aprun
line to do what you want. On the Cray, do a "man aprun" to see what
your options are. I think the key argument you need is -cc . The
Examples section has some (13!) use cases. When trying examples in
Swift/T, you can edit the first lines of your STC-generated Tcl script
to print the hostname or other things for debugging.
On 04/22/2013 09:12 AM, Scott Krieder wrote:
> Hi All,
> I was just wondering. When I run a multinode Swift application and
> give it 2 workers and 2 nodes on Raven, is there some way to force
> each worker to run on a separate node? For an initial test I would
> like to map 1 worker per GPU node.
> Any tips on how I might be able to control how the workers are
> established?
> Thanks,
> Scott
> Scott J. Krieder
> C: 419-685-0410
> E: skrieder at iit.edu <mailto:skrieder at iit.edu>
> http://datasys.cs.iit.edu/~skrieder/
> <http://datasys.cs.iit.edu/%7Eskrieder/>
> ExM-user mailing list
> ExM-user at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20130422/a598bdc3/attachment.html>
More information about the ExM-user
