[ExM Users] Installing Swift/T on Raven
Scott Krieder skrieder at iit.edu
Tue Apr 16 17:25:51 CDT 2013
Ok, thank you!
On Tue, Apr 16, 2013 at 11:32 PM, Justin M Wozniak <wozniak at mcs.anl.gov>wrote:
> I missed that note about blob.h .  That is just a warning, as far as I
> know it does not hurt anything.
> On 04/12/2013 03:02 PM, Scott Krieder wrote:
> Hi Justin,
>  For ADLB it doesn't recognize --with-mpi or --with-mpi-dir in the
> configure file. So I pointed both flags to use the default:
> ./configure --prefix=/home/users/p01684/Public/sfw/lb CC=gcc
> CFLAGS=-I/opt/cray/mpt/default/gni/mpich2-gnu/46/include
> LDFLAGS="-L/opt/cray/mpt/default/gni/mpich2-gnu/46/lib -lmpich"
> --with-c-utils=/home/users/p01684/Public/sfw/c-utils
>  I modified the Makefile and swapped gcc for two instances of mpicc.
>  I then installed SWIG from source with the configuration:
> ./configure --prefix=/home/users/p01684/Public/sfw/swig --without-pcre
>  I configure turbine with:
> ./configure --prefix=/home/users/p01684/Public/sfw/turbine
> --with-mpi=/opt/cray/mpt/default/gni/mpich2-gnu/46
>  However on "make package" there is an error with one of the blob header
> files:
> p01684 at raven:~/exm/turbine/trunk/code> make package SWIG
> src/tcl/blob/SwiftBlob.i src/tcl/blob/blob.h:25: Warning 201: Unable to
> find 'stdbool.h'
>  Do you know if there is a module I can load so swig can find the
> stdbool.h?
>  Thank you,
> Scott
> On Fri, Apr 12, 2013 at 1:44 PM, Justin M Wozniak <wozniak at mcs.anl.gov>wrote:
>> That configure line points --prefix= ... /c-utils
>> Also, CFLAGS=-I... should point to an include directory.
>> Try setting
>> and let me know what happens.  I will try to get on Raven soon to test
>> this.
>> On 04/12/2013 12:57 PM, Scott Krieder wrote:
>>   Hi Justin,
>> This is from a tarball from my machine where GeMTC and Swift are working,
>> I haven't updated past version 6770. Sorry to bounce around with errors but
>> I believe I had an earlier issue with the c-utils/adlb install that lead to
>> this turbine issue. When configuring adlb I point it at the c-utils install
>> and I get an error regarding the MPI version.
>> I'm running:
>> ./configure --prefix=/home/users/p01684/Public/c-utils CC=gcc
>> I noticed that there are many folders in:
>> /opt/cray/mpt/
>> Is there a good way to identify which version I should use within
>> /opt/cray/mpt? Or am I wrong in assuming that this versioning is what is
>> causing the "Could not preprocess maint/mpi_version.cpp" error?
>> Thanks,
>> Scott
>> ==error message==
>> checking for cp that supports -u... yes
>> using MPE: no
>> checking for /home/users/p01684/Public/sfw/c-utils/include/c-utils.h...
>> yes
>> using ExM c-utils in /home/users/p01684/Public/sfw/c-utils ...
>> checking MPI version... maint/mpi_version.cpp:23:17: error: mpi.h: No
>> such file or directory
>> configure: error: Could not preprocess maint/mpi_version.cpp
>>  On Fri, Apr 12, 2013 at 11:28 AM, Justin M Wozniak <wozniak at mcs.anl.gov>wrote:
>>>   Hi
>>> Is this with trunk or with the release package?
>>> --with-mpi-dir may have been replaced by --with-mpi
>>>     Justin
>>> On 04/12/2013 11:05 AM, Scott Krieder wrote:
>>>   Hi All,
>>>  I'm trying to install Swift/T on Raven. I followed the notes about
>>> Cray systems.
>>>  When I configure turbine with:
>>> --enable-custom --with-mpi-dir=/opt/cray/mpt/default/xt/gemini/mpich2-gnu/46
>>>  I get a long error about "could not find directory" in reference to
>>> mpicc. Is there something I should do in addition to the --with-mpi flag?
>>>  Thanks,
>>> Scott
>>>  ==Error Message==
>>>   checking for
>>> /ufs/home/users/p01684/Public/sfw/c-utils/include/c-utils.h... yes
>>> which: no mpicc in
>>> (/opt/pbs/10.4.0.101257/bin:/opt/cray/atp/1.6.2/bin:/opt/cray/rca/1.0.0-2.0401.38656.2.2.gem/bin:/opt/cray/pmi/4.0.1-1.0000.9421.73.3.gem/bin:/opt/toolworks/totalview.8.11.0-1/bin:/opt/totalview-support/1.1.4/bin:/opt/cray/cce/8.1.4/cray-binutils/x86_64-unknown-linux-gnu/bin:/opt/cray/cce/8.1.4/craylibs/x86-64/bin:/opt/cray/cce/8.1.4/cftn/bin:/opt/cray/cce/8.1.4/CC/bin:/opt/cray/xt-asyncpe/5.20.11/bin:/opt/cray/llm/default/bin:/opt/cray/llm/default/etc:/opt/cray/xpmem/0.1-2.0401.36790.4.3.gem/bin:/opt/cray/dmapp/3.2.1-1.0401.5983.4.5.gem/bin:/opt/cray/ugni/4.0-1.0401.5928.9.5.gem/bin:/opt/cray/udreg/2.3.2-1.0401.5929.3.3.gem/bin:/opt/cray/lustre-cray_gem_s/1.8.6_2.6.32.59_0.7.1_1.0401.6845.9.1-1.0401.38658.11.3/sbin:/opt/cray/lustre-cray_gem_s/1.8.6_2.6.32.59_0.7.1_1.0401.6845.9.1-1.0401.38658.11.3/bin:/opt/cray/MySQL/5.0.64-1.0000.5053.22.1/sbin:/opt/cray/MySQL/5.0.64-1.0000.5053.22.1/bin:/opt/cray/sdb/1.0-1.0401.38148.4.27.gem/bin:/opt/cray/n
>>> odestat/2 . 2-1.0401. 37252.2.1.gem /bin:/opt /modules/
>>> 3.2.6.7/bin:/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/usr/games:/usr/lib64/jvm/jre/bin:/usr/lib/mit/bin:/usr/lib/mit/sbin:.:/usr/lib/qt3/bin:/opt/cray/bin
>>>   ./configure: line 4032: ((: !  : syntax error: operand expected
>>> (error token is " ")
>>> checking for 0... no
>>> configure: error: Could not find directory
>>> Scott J. Krieder
>>>  C: 419-685-0410
>>>  E: skrieder at iit.edu
>>>  http://datasys.cs.iit.edu/~skrieder/
>>> _______________________________________________
>>> ExM-user mailing listExM-user at lists.mcs.anl.govhttps://lists.mcs.anl.gov/mailman/listinfo/exm-user
>>> Justin M Wozniak
>> Scott J. Krieder
>>  C: 419-685-0410
>> Justin M Wozniak
> Scott J. Krieder
>  C: 419-685-0410
> Justin M Wozniak
Scott J. Krieder
C: 419-685-0410
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20130417/9e5ba30b/attachment-0001.html>
More information about the ExM-user mailing list
