[Darshan-users] Error: incompatible darshan file.
Snyder, Shane ssnyder at mcs.anl.gov
Thu Mar 9 08:25:48 CST 2023
Hi Zoya,
That warning message implies darshan-parser believes it is using older Darshan libraries than what generated the log. Are you sure you're not always invoking darshan-parser built by the 3.3.1 library you mention?
I would try to verify on a fresh build/install of a 3.4.1+ release on your laptop to make sure. Maybe even try running darshan-parser directly from the build directory to ensure install prefixes aren't somehow getting mixed up or something.
--Shane
From: Darshan-users <darshan-users-bounces at lists.mcs.anl.gov> on behalf of Zoya Masih <zoyamasih92 at gmail.com>
Sent: Thursday, March 9, 2023 6:07 AM
To: darshan-users at lists.mcs.anl.gov <darshan-users at lists.mcs.anl.gov>
Subject: [Darshan-users] Error: incompatible darshan file.
Hello,
I have installed Darshan version 3.4.1 on an HPC cluster and generated a log file without any problem. Then copied the log file to my own laptop, which has version 3.4.2 installed. When I do darshan-parser, I get the error message:
Error: expected version 3.21, but got 3.41
Error: failed to read darshan log file header.
(also the same problem with version 3.4.1 on my laptop). There is no error when I do a parser for log files of older version 3.3.1
Would you please guide me to understand the issue?
Sincerely
Zoya Masih
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20230309/09068126/attachment-0001.html>
More information about the Darshan-users mailing list
