[Darshan-users] Module contains incomplete data
    Jiří Nádvorník
    nadvornik.ji at gmail.com
    Sun Apr 24 15:00:05 CDT 2022
Hi All,
I just tried out Darshan and the potential output seems perfect for my HDF5
MPI application! Although I'm not able to get there :(.
I have a log that has a big stamp "This darshan log contains incomplete
data".
When I run:
darshan-parser --show-incomplete  mylog.darshan |grep incomplete
Output is:
# *WARNING*: The POSIX module contains incomplete data!
# *WARNING*: The MPI-IO module contains incomplete data!
# *WARNING*: The STDIO module contains incomplete data!
Would you be able to point me to some setting that would improve the
measurements? Can I actually rely on the profiling results if it says the
data is incomplete in some of the categories?
Thank you very much for your help!
Cheers,
Jiri
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20220424/86def4a2/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20220424/86def4a2/attachment-0001.obj>
More information about the Darshan-users
