[Darshan-users] Logs not generated inspite throwing warning message
Phil Carns carns at mcs.anl.gov
Mon Jun 21 12:58:28 CDT 2021
Ah, Ok.  This is the problem then.  The log directory has to be on a
shared file system (e.g. nfs, lustre, etc.) that is visible to all
nodes.  The log is created and written using collective I/O operations,
so all of the ranks need to be able to access the same file simultaneously.
I'll open a ticket to investigate if there is a way to produce a more
helpful error message in this case.
thanks,
-Phil
On 6/21/21 5:50 PM, Hassan Asghar wrote:
> it is not shared directory, but i have install the same version of
> darshan on the other nodes as well.
> Regards,
> *Hassan Asghar*
> MS Computer Science
> Mobile: +92-321-1741755
> Personal Website: http://bit.ly/2OQ0egs <http://bit.ly/2OQ0egs>
> Google Scholar: https://bit.ly/3lVYuxF <https://bit.ly/3lVYuxF>
> On Mon, Jun 21, 2021 at 10:30 PM Phil Carns <carns at mcs.anl.gov
> <mailto:carns at mcs.anl.gov>> wrote:
>     Hi Hassan,
>     Is /darshan-logs/ a shared directory?
>     thanks,
>     -Phil
>     On 6/21/21 1:04 PM, Hassan Asghar wrote:
>>     Yes, I have set the log path and all permission are given when i
>>     run program on local machine it execute successfully but when i
>>     exceute on three nodes it show error.
>>     On Tue, 22 Jun 2021, 1:18 am Harms, Kevin, <harms at alcf.anl.gov
>>     <mailto:harms at alcf.anl.gov>> wrote:
>>         Hassan,
>>           did you create the  /darshan-logs directory? Looks like it
>>         might not be writeable.
>>           try: /darshan-logs/2021/6/21
>>           if you want to try a quick test, set DARSHAN_LOGFILE to the
>>         path/name of the log, like:
>>           DARSHAN_LOGFILE=/path/I/can/write/to/logfile.darshan
>>         kevin
>>         ________________________________________
>>         From: Darshan-users <darshan-users-bounces at lists.mcs.anl.gov
>>         <mailto:darshan-users-bounces at lists.mcs.anl.gov>> on behalf
>>         of Hassan Asghar <haxxanasghar at gmail.com
>>         <mailto:haxxanasghar at gmail.com>>
>>         Sent: Monday, June 21, 2021 12:35 AM
>>         To: darshan-users at lists.mcs.anl.gov
>>         <mailto:darshan-users at lists.mcs.anl.gov>
>>         Subject: [Darshan-users] Logs not generated inspite throwing
>>         warning message
>>         I am running darshan with mpich on a three-node cluster and
>>         my job executed successfully but not generated logs. error
>>         warning is given below at the end of the execution.
>>         [haxxanasghar at gpuserver2 ~]$ mpiexec -n 64 -f machinefile
>>         -env LD_PRELOAD /usr/l
>>          ocal/lib/libdarshan.so ./MADbench2 640 80 4 8 8 4 4
>>         MADbench 2.0 IO-mode
>>         no_pe = 64  no_pix = 640  no_bin = 80  no_gang = 4 sblocksize
>>         = 8  fblocksize =                         8  r_mod = 4  w_mod = 4
>>         IOMETHOD = POSIX  IOMODE = SYNC  FILETYPE = UNIQUE REMAP = CUSTOM
>>         S_cc         0.02   [      0.02:      0.03]
>>         S_bw         0.01   [      0.01:      0.01]
>>         S_w          0.03   [      0.03:      0.04]
>>         S_total      0.07   [      0.07:      0.07]
>>         W_cc         0.04   [      0.03:      0.05]
>>         W_bw         0.22   [      0.20:      0.23]
>>         W_r          0.02   [      0.02:      0.02]
>>         W_w          0.01   [      0.01:      0.01]
>>         W_total      0.28   [      0.28:      0.29]
>>         C_cc         0.01   [      0.01:      0.01]
>>         C_bw         0.00   [      0.00:      0.00]
>>         C_r          0.01   [      0.01:      0.01]
>>         C_total      0.02   [      0.02:      0.02]
>>         dC[0] = 0.00000e+00
>>         darshan_library_warning: unable to create log file
>>         /darshan-logs/2021/6/21/haxxa
>>          nas_MADbench2_id29484-29484_6-21-52165-1341319014666854881.darshan_partial.
>>         Regards,
>>         Hassan Asghar
>>         MS Computer Science
>>     _______________________________________________
>>     Darshan-users mailing list
>>     Darshan-users at lists.mcs.anl.gov  <mailto:Darshan-users at lists.mcs.anl.gov>
>>     https://lists.mcs.anl.gov/mailman/listinfo/darshan-users  <https://lists.mcs.anl.gov/mailman/listinfo/darshan-users>
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20210621/d0f224de/attachment-0001.html>
More information about the Darshan-users mailing list
