[Darshan-users] Logs not generated inspite throwing warning message
Phil Carns
carns at mcs.anl.gov
Mon Jun 21 12:30:01 CDT 2021
Hi Hassan,
Is /darshan-logs/ a shared directory?
thanks,
-Phil
On 6/21/21 1:04 PM, Hassan Asghar wrote:
> Yes, I have set the log path and all permission are given when i run
> program on local machine it execute successfully but when i exceute on
> three nodes it show error.
> On Tue, 22 Jun 2021, 1:18 am Harms, Kevin, <harms at alcf.anl.gov
> <mailto:harms at alcf.anl.gov>> wrote:
> Hassan,
> did you create the /darshan-logs directory? Looks like it might
> not be writeable.
> try: /darshan-logs/2021/6/21
> if you want to try a quick test, set DARSHAN_LOGFILE to the
> path/name of the log, like:
> DARSHAN_LOGFILE=/path/I/can/write/to/logfile.darshan
> kevin
> From: Darshan-users <darshan-users-bounces at lists.mcs.anl.gov
> <mailto:darshan-users-bounces at lists.mcs.anl.gov>> on behalf of
> Hassan Asghar <haxxanasghar at gmail.com <mailto:haxxanasghar at gmail.com>>
> Sent: Monday, June 21, 2021 12:35 AM
> To: darshan-users at lists.mcs.anl.gov
> <mailto:darshan-users at lists.mcs.anl.gov>
> Subject: [Darshan-users] Logs not generated inspite throwing
> warning message
> I am running darshan with mpich on a three-node cluster and my job
> executed successfully but not generated logs. error warning is
> given below at the end of the execution.
> [haxxanasghar at gpuserver2 ~]$ mpiexec -n 64 -f machinefile -env
> LD_PRELOAD /usr/l ocal/lib/libdarshan.so ./MADbench2 640 80 4 8 8 4 4
> MADbench 2.0 IO-mode
> no_pe = 64 no_pix = 640 no_bin = 80 no_gang = 4 sblocksize =
> 8 fblocksize =
> 8 r_mod = 4 w_mod = 4
> IOMETHOD = POSIX IOMODE = SYNC FILETYPE = UNIQUE REMAP = CUSTOM
> S_cc 0.02 [ 0.02: 0.03]
> S_bw 0.01 [ 0.01: 0.01]
> S_w 0.03 [ 0.03: 0.04]
> S_total 0.07 [ 0.07: 0.07]
> W_cc 0.04 [ 0.03: 0.05]
> W_bw 0.22 [ 0.20: 0.23]
> W_r 0.02 [ 0.02: 0.02]
> W_w 0.01 [ 0.01: 0.01]
> W_total 0.28 [ 0.28: 0.29]
> C_cc 0.01 [ 0.01: 0.01]
> C_bw 0.00 [ 0.00: 0.00]
> C_r 0.01 [ 0.01: 0.01]
> C_total 0.02 [ 0.02: 0.02]
> dC[0] = 0.00000e+00
> darshan_library_warning: unable to create log file
> /darshan-logs/2021/6/21/haxxa
> nas_MADbench2_id29484-29484_6-21-52165-1341319014666854881.darshan_partial.
> Regards,
> Hassan Asghar
> MS Computer Science
> Mobile: +92-321-1741755
> Personal Website: http://bit.ly/2OQ0egs <http://bit.ly/2OQ0egs>
> Google Scholar: https://bit.ly/3lVYuxF <https://bit.ly/3lVYuxF>
> Darshan-users mailing list
> Darshan-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20210621/8de5589c/attachment-0001.html>
More information about the Darshan-users
