[Darshan-users] PyDarshan issues
Jeffrey Layton
laytonjb at gmail.com
Wed Jul 14 09:12:34 CDT 2021
Great! Thanks!
I thought I would work through the notebooks for PyDarshan. I use Anaconda
for my Python which is the source of the issue I think.
I used pip to install PyDarshan on my system (most of the time I can get
pip installed Python modules to work with conda). I'm trying the
01_darsha_introduction notebook. I tried running the first cell and got the
following error:
---------------------------------------------------------------------------ValueError
Traceback (most recent call
last)<ipython-input-1-923d294d02c5> in <module>----> 1 import darshan
2 3 report =
darshan.DarshanReport("example-logs/example.darshan", read_all=True)
# Default behavior 4 report.info()
~/.local/lib/python3.8/site-packages/darshan/__init__.py in <module>
17 18 #from darshan.backend.cffi_backend import *---> 19 from
darshan.report import DarshanReport 20 21
~/.local/lib/python3.8/site-packages/darshan/report.py in <module>
8 9 ---> 10 import darshan.backend.cffi_backend as backend
11 12 import json
~/.local/lib/python3.8/site-packages/darshan/backend/cffi_backend.py
in <module> 9 10 import numpy as np---> 11 import pandas as
pd 12 13 import logging
~/anaconda3/lib/python3.8/site-packages/pandas/__init__.py in <module>
27 28 try:---> 29 from pandas._libs import hashtable as
_hashtable, lib as _lib, tslib as _tslib 30 except ImportError as
e: # pragma: no cover 31 # hack but overkill to use re
~/anaconda3/lib/python3.8/site-packages/pandas/_libs/__init__.py in
<module> 11 12 ---> 13 from pandas._libs.interval import
Interval 14 from pandas._libs.tslibs import ( 15 NaT,
pandas/_libs/interval.pyx in init pandas._libs.interval()
ValueError: numpy.ndarray size changed, may indicate binary
incompatibility. Expected 88 from C header, got 80 from PyObject
I'm guessing this is an interaction issue between conda and pip due to the
last line. Any thoughts on this? I could ask for a PyDarshan package for
conda and I wish I could help but I would be less than worthless in that
regard.
Thanks for any advice!
Jeff
On Wed, Jul 14, 2021 at 10:02 AM Snyder, Shane <ssnyder at mcs.anl.gov> wrote:
> Hi Jeff,
> Fire away! This mailing list and issues on our GitHub page (
> https://github.com/darshan-hpc/darshan) are the best place for both
> Darshan and PyDarshan issues.
> <https://github.com/darshan-hpc/darshan>
> darshan-hpc/darshan <https://github.com/darshan-hpc/darshan>
> Darshan I/O characterization tool. Contribute to darshan-hpc/darshan
> development by creating an account on GitHub.
> github.com
> Thanks,
> --Shane
> *From:* Darshan-users <darshan-users-bounces at lists.mcs.anl.gov> on behalf
> of Jeffrey Layton <laytonjb at gmail.com>
> *Sent:* Wednesday, July 14, 2021 8:11 AM
> *To:* darshan-users at lists.mcs.anl.gov <darshan-users at lists.mcs.anl.gov>
> *Subject:* [Darshan-users] PyDarshan issues
> Good morning,
> Is this is a good place to bring up PyDarshan issues or is there a better
> one?
> Thanks!
> Jeff
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20210714/4daef2f9/attachment.html>
More information about the Darshan-users
