[Darshan-users] profiling DASK application using darshan
Razvan Stefanescu
razvan.stefanescu at spire.com
Sun Oct 18 13:29:57 CDT 2020
Hello Sandra,
What command did you actually use for tracing your python code? Did you use
something like
mpiexec -n 4 -env LD_PRELOAD $PATH/libdarshan.so python script.py ?
Thank you,
Razvan
On Sun, Oct 18, 2020 at 7:30 AM Sandra A. Mendez <smendez.fi.unju at gmail.com>
wrote:
> Hi Razvan,
> I have traced a python program by using Darshan. You only need to set up
> the DARSHAN_ENABLE_NONMPI variable as follows:
> export DARSHAN_ENABLE_NONMPI=1
> Before running your application. Only a comment, the maximum number of
> files to trace by Darshan is 1024 files per parallel task. In case of
> python applications, Darshan traces all the files opened not only the
> application files (but also the files opened by the python libraries). So
> take care if your application overcomes that limit.
> Thanks,
> Sandra.-
> On Sun, 18 Oct 2020 at 15:09, Razvan Stefanescu <
> razvan.stefanescu at spire.com> wrote:
>> Hello All,
>> Following the documentation note saying that Darshan instrumentation of
>> non-MPI applications is only possible with dynamically-linked applications,
>> it seems I have to convert the multiprocessing and multithreading DASK code
>> to a dynamically-linked code. I know some folks were able to profile Spark
>> and TensorFlow codes with Darshan, so I wonder if you could provide some
>> suggestions about creating such dynamically-linked code.
>> Thank you,
>> Razvan
>> *RAZVAN STEFANESCU *
>> Head of Statistics and Machine Learning Branch
>> Senior Data Assimilation and Data Scientist
>> *Spire Global, Inc.*
>> 1050 Walnut Street, Suite 402, Boulder, CO 80302 USA
>> +1-720- <7206432245>*643-2231*
>> +1-850-443-1718 <4178491948>
>> Darshan-users mailing list
>> Darshan-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20201018/a5af270b/attachment.html>
More information about the Darshan-users
