[Darshan-users] Problem with DARSHAN_CHECK_ERR
François Trahay
francois.trahay at telecom-sudparis.eu
Tue Jan 7 10:18:15 CST 2020
Due to a missing environment variable, I got the following message when
running an application with darshan:
darshan_library_warning: unable to create log file .
This incomplete message is due to the DARSHAN_CHECK_ERR macro in
darshan-runtime/lib/darshan-core.c that only prints the message format,
but does not the variadic arguments. The attached patch fixes the problem.
Regards.
François
diff --git a/darshan-runtime/lib/darshan-core.c b/darshan-runtime/lib/darshan-core.c
index 2d7bc42..332e69e 100644
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -171,7 +171,7 @@ static double darshan_core_wtime_absolute(void);
PMPI_Allreduce(MPI_IN_PLACE, &__ret, 1, MPI_INT, MPI_LOR, final_core->mpi_comm); \
if(__ret != 0) { \
if(my_rank == 0) { \
- DARSHAN_WARN(__err_str); \
+ DARSHAN_WARN(__err_str, ## __VA_ARGS__); \
if(log_created) \
unlink(logfile_name); \
@@ -184,7 +184,7 @@ static double darshan_core_wtime_absolute(void);
/* Non-MPI variant of darshan logging helpers */
#define DARSHAN_CHECK_ERR(__ret, __err_str, ...) do { \
if(__ret != 0) { \
if(log_created) \
goto exit; \
More information about the Darshan-users
