[Darshan-users] Darshan & EPCC benchio different behaviour
Piero LANUCARA p.lanucara at cineca.it
Fri Feb 7 09:15:02 CST 2020
yes...correct
Piero
Il 07/02/2020 16:07, Harms, Kevin ha scritto:
> Piero,
>    just to confirm, the serial case is still running in parallel, 36 processes, but the I/O is only from rank 0?
> kevin
> From: Darshan-users <darshan-users-bounces at lists.mcs.anl.gov> on behalf of Piero LANUCARA <p.lanucara at cineca.it>
> Sent: Wednesday, February 5, 2020 4:56 AM
> To: darshan-users at lists.mcs.anl.gov
> Subject: Re: [Darshan-users] Darshan & EPCC benchio different behaviour
> p.s
> to be more "verbose" I add to the discussion:
> Darshan output for the "serial" run (serial.pdf)
> Darshan output for the MPI-IO run (mpiio.pdf)
> benchio output for "serial" run (serial.out)
> benchio output for "MPI-IO" run (mpi-io.out)
> thanks
> Piero
> Il 04/02/2020 19:44, Piero LANUCARA ha scritto:
>> Dear all
>> I'm using Darshan to measure EPCC benchio benchmark
>> (https://github.com/EPCCed/benchio) behaviour on a given x86 Tier1
>> machine.
>> running two benchio tests (MPI-IO and serial) a different behaviour
>> appear
>> while Darhsan pdf log file is able to recover the estimated time and
>> bandwidth in the MPI-IO case, the "serial" run is completely
>> underestimated by Darshan (the time and bandwidth are less/greater
>> than benchio output).
>> Suggestions are welcomed
>> thanks
>> Piero
>> Darshan-users mailing list
>> Darshan-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
More information about the Darshan-users mailing list
