[Darshan-users] Darshan & EPCC benchio different behaviour
Harms, Kevin
harms at alcf.anl.gov
Fri Feb 7 09:07:15 CST 2020
Piero,
just to confirm, the serial case is still running in parallel, 36 processes, but the I/O is only from rank 0?
kevin
From: Darshan-users <darshan-users-bounces at lists.mcs.anl.gov> on behalf of Piero LANUCARA <p.lanucara at cineca.it>
Sent: Wednesday, February 5, 2020 4:56 AM
To: darshan-users at lists.mcs.anl.gov
Subject: Re: [Darshan-users] Darshan & EPCC benchio different behaviour
p.s
to be more "verbose" I add to the discussion:
Darshan output for the "serial" run (serial.pdf)
Darshan output for the MPI-IO run (mpiio.pdf)
benchio output for "serial" run (serial.out)
benchio output for "MPI-IO" run (mpi-io.out)
thanks
Piero
Il 04/02/2020 19:44, Piero LANUCARA ha scritto:
> Dear all
> I'm using Darshan to measure EPCC benchio benchmark
> (https://github.com/EPCCed/benchio) behaviour on a given x86 Tier1
> machine.
> running two benchio tests (MPI-IO and serial) a different behaviour
> appear
> while Darhsan pdf log file is able to recover the estimated time and
> bandwidth in the MPI-IO case, the "serial" run is completely
> underestimated by Darshan (the time and bandwidth are less/greater
> than benchio output).
> Suggestions are welcomed
> thanks
> Piero
> Darshan-users mailing list
> Darshan-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
More information about the Darshan-users
