[Darshan-users] LaTeX generation (phase1) failed in darshan-job-summary.pl utility
Carns, Philip H.
carns at mcs.anl.gov
Fri Sep 13 13:06:46 CDT 2019
Great, thanks for the follow up!
From: Darshan-users <darshan-users-bounces at lists.mcs.anl.gov> on behalf of Ayşe Arslan via Darshan-users <darshan-users at lists.mcs.anl.gov>
Sent: Sunday, September 8, 2019 6:27 PM
To: darshan-users at lists.mcs.anl.gov <darshan-users at lists.mcs.anl.gov>
Subject: Re: [Darshan-users] LaTeX generation (phase1) failed in darshan-job-summary.pl utility
Solved with
sudo apt-get install texlive-latex-extra
Thanks.
Ayşe Arslan <aysearslan2491 at gmail.com<mailto:aysearslan2491 at gmail.com>>, 8 Eyl 2019 Paz, 22:01 tarihinde şunu yazdı:
Dear all,
I installed darshan, and I am trying to create a PDF report by using the command:
darshan-job-summary.pl<http://darshan-job-summary.pl> <trace file>.darshan
I am using an example output file to create pdf file as follows:
/usr/local/darshan_317_ompi/bin/darshan-job-summary.pl<http://darshan-job-summary.pl> ~/darshan-3.1.7/darshan-test/example-output/mpi-io-test-ppc64-3.1.7.darshan
But it stops and does not work.
When I trace darshan-job-summary.pl<http://darshan-job-summary.pl>, I see it stops at the following line.
$system_rc = system "$pdflatex $latex_cmd_line > latex.output
When I change mode as nonstopmode as follows,
$system_rc = system "$pdflatex -interaction=nonstopmode -halt-on-error $latex_cmd_line > latex.output
It enters the following part and gives error.
if($system_rc)
print("LaTeX generation (phase1) failed [$system_rc], aborting summary creation.\n");
print("error log:\n");
system("tail latex.output");
exit(1);
Detailed output:
/usr/local/darshan_317_ompi/bin/darshan-job-summary.pl<http://darshan-job-summary.pl> ~/darshan317/darshan-3.1.7/darshan-test/example-output/mpi-io-test-x86_64-3.1.6.darshan
Slowest unique file time: 0.000434
Slowest shared file time: 0.054095
Total bytes read and written by app (may be incorrect): 134218050
Total absolute I/O time: 0.054529
**NOTE: above shared and unique file times calculated using MPI-IO timers if MPI-IO interface used on a given file, POSIX timers otherwise.
LaTeX generation (phase1) failed [256], aborting summary creation.
error log:
or enter new name. (Default extension: sty)
Enter file name:
! Emergency stop.
<read *>
l.6 \usepackage
{subfigure}^^M
! ==> Fatal error occurred, no output PDF file produced!
Transcript written on summary.log.
What is the problem, is there any idea how can I fix it ? I would appreciate any help.
Thank you.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20190913/d08bf1ee/attachment.html>
More information about the Darshan-users
