[Darshan-users] LaTeX generation (phase1) failed in darshan-job-summary.pl utility
Ayşe Arslan
aysearslan2491 at gmail.com
Sun Sep 8 17:27:19 CDT 2019
Solved with
sudo apt-get install texlive-latex-extra
Thanks.
Ayşe Arslan <aysearslan2491 at gmail.com>, 8 Eyl 2019 Paz, 22:01 tarihinde
şunu yazdı:
> Dear all,
> I installed darshan, and I am trying to create a PDF report by using the
> command:
> darshan-job-summary.pl <trace file>.darshan
> I am using an example output file to create pdf file as follows:
> /usr/local/darshan_317_ompi/bin/darshan-job-summary.pl
> ~/darshan-3.1.7/darshan-test/example-output/mpi-io-test-ppc64-3.1.7.darshan
> But it stops and does not work.
> When I trace darshan-job-summary.pl, I see it stops at the following
> line.
> $system_rc = system "$pdflatex $latex_cmd_line > latex.output
> When I change mode as nonstopmode as follows,
> $system_rc = system "$pdflatex -interaction=nonstopmode -halt-on-error
> It enters the following part and gives error.
> if($system_rc)
> print("LaTeX generation (phase1) failed [$system_rc], aborting summary
> creation.\n");
> print("error log:\n");
> system("tail latex.output");
> exit(1);
> Detailed output:
> ~/darshan317/darshan-3.1.7/darshan-test/example-output/mpi-io-test-x86_64-3.1.6.darshan
> Slowest unique file time: 0.000434
> Slowest shared file time: 0.054095
> Total bytes read and written by app (may be incorrect): 134218050
> Total absolute I/O time: 0.054529
> **NOTE: above shared and unique file times calculated using MPI-IO timers
> if MPI-IO interface used on a given file, POSIX timers otherwise.
> LaTeX generation (phase1) failed [256], aborting summary creation.
> error log:
> or enter new name. (Default extension: sty)
> Enter file name:
> ! Emergency stop.
> <read *>
> l.6 \usepackage
> {subfigure}^^M
> ! ==> Fatal error occurred, no output PDF file produced!
> Transcript written on summary.log.
> What is the problem, is there any idea how can I fix it ? I would
> appreciate any help.
> Thank you.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20190909/529726f5/attachment.html>
More information about the Darshan-users
