[Darshan-users] Help needed, Darshan keeps crashing in Lustre filesystem
    Liem, Radita
    Liem at itc.rwth-aachen.de
    Mon Oct 14 10:52:12 CDT 2019
Dear all,
I would like to ask for some suggestion on how to fix the problem with
Darshan keeps crashing when running on Lustre filesystem.
The error message as follow:
using old ioctl(LL_IOC_LOV_GETSTRIPE) on [0x2c002048c:0x25:0x0], use
llapi_layout_get_by_path()
The application works without Darshan and it only crashes when using Lustre
(I have tried running the application with Darshan in other filesystems)
Previously it worked at the same Lustre node before the administrator made
cluster update.
Is there any new version of Darshan or another workaround for this problem?
Thank you in advance
Radita Liem, M. Sc.
IT Center
Group: High Performance Computing
Division: Computational Science and Engineering
RWTH Aachen University
Seffenter Weg 23
D 52074  Aachen (Germany)
Fax: +49 241 80-624765
 <mailto:liem at itc.rwth-aachen.de> liem at itc.rwth-aachen.de
www.itc.rwth-aachen.de <http://www.itc.rwth-aachen.de>
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20191014/392373fa/attachment.html>
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20191014/392373fa/attachment.p7s>
More information about the Darshan-users
