[Darshan-users] Using darshan to characterize PHDF characteristics
Carns, Philip H.
carns at mcs.anl.gov
Fri Jan 18 08:55:52 CST 2019
Hi Mahzad,
Everything you are doing looks fine to me. It's possible that we have a bug that is being triggered in darshan-convert (this is a command line utility called within darshan-summary-per-file.sh to help split up the data).
Are you able to run darshan-job-summary.pl and/or darshan-parser on the log file?
Can you share your log file for us to have a look at it and see if we can reproduce?
thanks!
-Phil
On 2019-01-15 19:54:20-05:00 Darshan-users wrote:
Hello all,
I have a python code and I am using parallel hdf5 through h5py.
I compiled darshan with the following options:
./configure --prefix=/home/mkhoshle/installs/darshan --with-mem- align=8 --with-log-path=/oasis/scratch/comet/mkhoshle/temp_project/darshan-logs --with-jobid-env=PBS_JOBID --enable-HDF5-post-1.10 CC=mpicc
I set the the environment variable LD_PRELOAD as:
export LD_PRELOAD=/home/mkhoshle/installs/darshan/lib/libdarshan.so:/home/mkhoshle/hdf5/v1.10.1/lib/libhdf5.so
And I am using Darshan 3.1.5.
I can run my code with no error but when I run darshan-summary-per-file.sh I get the following error and I get no output.
darshan-summary-per-file.sh /oasis/scratch/comet/mkhoshle/temp_project/darshan-logs/2019/1/15/mkhoshle_python_id10574_1-15-58292-3565400970146387705_1.darshan /oasis/scratch/comet/mkhoshle/temp_project/darshan/58292
Status: Generating summary for file 1 of 64: __init__.py
/home/mkhoshle/installs/darshan/bin/darshan-summary-per-file.sh: line 63: 27764 Segmentation fault darshan-convert --file $hash $1 $2/$file.darshan
darshan-summary-per-file.sh done. Results can be found in /oasis/scratch/comet/mkhoshle/temp_project/darshan/58292/*.pdf.
Am I doing anything wrong?
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20190118/7604f42a/attachment.html>
More information about the Darshan-users
