[Darshan-users] Unexpected Darshan I/O characterization running IOR BM
Cormac Garvey
cormac.t.garvey at gmail.com
Wed Nov 21 16:36:24 CST 2018
Hi Phil,
Thanks for looking into this for me.
Here is the information you requested.
ldd ./ior
linux-vdso.so.1 => (0x00007fff0237c000)
libm.so.6 => /lib64/libm.so.6 (0x00007fce3e88f000)
libmpi.so.12 =>
/opt/intel/compilers_and_libraries_2016.3.223/linux/mpi/intel64/lib/libmpi.so.12
(0x00007fce3e0bf000)
libc.so.6 => /lib64/libc.so.6 (0x00007fce3dcfc000)
/lib64/ld-linux-x86-64.so.2 (0x000055de86c95000)
librt.so.1 => /lib64/librt.so.1 (0x00007fce3daf4000)
libdl.so.2 => /lib64/libdl.so.2 (0x00007fce3d8ef000)
libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007fce3d6d9000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x00007fce3d4bd000)
[testusera at ip-0A021004 bin]$
Here is the info on testfile.0 and testfile.1 before executing the IOR read
test.
[testusera at ip-0A021004 testing]$ pwd
/mnt/beegfs/testing
[testusera at ip-0A021004 testing]$ ls -lt
total 4194304
-rw-r--r--. 1 testusera domain users 2147483648 Nov 21 22:18 testfile.1
-rw-r--r--. 1 testusera domain users 2147483648 Nov 21 22:17 testfile.0
[testusera at ip-0A021004 testing]$ stat testfile.0
File: ‘testfile.0’
Size: 2147483648 Blocks: 4194304 IO Block: 524288 regular file
Device: 29h/41d Inode: 2501562826468697566 Links: 1
Access: (0644/-rw-r--r--) Uid: (1264001104/testusera) Gid:
(1264000513/domain users)
Context: system_u:object_r:tmp_t:s0
Access: 2018-11-21 22:17:41.000000000 +0000
Modify: 2018-11-21 22:17:56.000000000 +0000
Change: 2018-11-21 22:17:56.000000000 +0000
Birth: -
Result from running the IOR read test.
IOR-3.2.0: MPI Coordinated Test of Parallel I/O
Began : Wed Nov 21 22:22:52 2018
Command line : /avere/apps/ior/bin/ior -a POSIX -B -r -k -z -v -o
/mnt/beegfs/testing/testfile -i 2 -m -t 32m -b 256M -d 1
Machine : Linux ip-0A021005
Start time skew across all tasks: 0.00 sec
TestID : 0
StartTime : Wed Nov 21 22:22:52 2018
Path : /mnt/beegfs/testing
FS : 11.8 TiB Used FS: 0.0% Inodes: 0.0 Mi Used
Inodes: -nan%
Participating tasks: 8
Options:
api : POSIX
apiVersion :
test filename : /mnt/beegfs/testing/testfile
access : single-shared-file
type : independent
segments : 1
ordering in a file : random
ordering inter file : no tasks offsets
tasks : 8
clients per node : 8
repetitions : 2
xfersize : 32 MiB
blocksize : 256 MiB
aggregate filesize : 2 GiB
Results:
access bw(MiB/s) block(KiB) xfer(KiB) open(s) wr/rd(s) close(s)
total(s) iter
delaying 1 seconds . . .
Commencing read performance test: Wed Nov 21 22:22:53 2018
read 481.88 262144 32768 0.020854 4.23 2.97
4.25 0
Commencing read performance test: Wed Nov 21 22:22:58 2018
read 609.04 262144 32768 0.020336 3.34 2.06
3.36 1
Max Read: 609.04 MiB/sec (638.62 MB/sec)
Summary of all tests:
Operation Max(MiB) Min(MiB) Mean(MiB) StdDev Max(OPs)
Min(OPs) Mean(OPs) StdDev Mean(s) Test# #Tasks tPN reps fPP reord
reordoff reordrand seed segcnt blksiz xsize aggs(MiB) API RefNum
read 609.04 481.88 545.46 63.58 19.03
15.06 17.05 1.99 3.80633 0 8 8 2 0 0
1 0 0 1 268435456 33554432 2048.0 POSIX 0
Finished : Wed Nov 21 22:23:02 2018
I also ran a test without the -B option and got the same result (no reads
recorded)?
Cormac.
On Wed, Nov 21, 2018 at 1:46 PM Carns, Philip H. via Darshan-users <
darshan-users at lists.mcs.anl.gov> wrote:
> Hi Cormac,
> That's strange. The -i 2 and -m options are making IOR attempt to read
> two files: testfile.0 and testfile.1. Darshan is definitely aware of those
> files, but not only are the read counters missing but also the open
> counters. It only shows a stat from each rank for the files in question.
> Can you confirm that both of the files exist and are big enough to
> accommodate the requested read volume? I wonder if IOR might stat the
> files up front and exit early if they aren't the correct size?
> Could you also share the output of "ldd ior"? I'm curious to make sure
> there isn't anything unusual about the libraries linked in, but usually if
> that were a problem you wouldn't get a log at all.
> Also one last idea, does the behavior change if you remove the -B
> (O_DIRECT) option? That shouldn't matter from Darshan's perspective, but
> it might not hurt to check.
> thanks,
> -Phil
> On 2018-11-20 19:59:55-05:00 Darshan-users wrote:
> Hello,
> I recently installed Darshan 3.1.6 on Microsoft Azure VM running Centos
> 7.4.
> I got an unexpected result using Darshan to characterize the I/O for an
> IOR benchmark
> experiment.
> export
> LD_PRELOAD=/avere/apps/spack/linux-centos7-x86_64/gcc-4.8.5/darshan-runtime-3.1.6-daohky4yevagxajjl33lwk472lcgn6g4/lib/libdarshan.so
> BLOCKSIZE=256M
> mpirun -np 8 ior -a POSIX -B -r -k -z -v -o $FILEPATH -i 2 -m -t 32m -b
> 256M -d 1
> After the job completed, a Darshan log file was created, the resulting
> text report (darshan-parser_ior_read_shared.out, its attached) was
> generated using the following command
> darshan-parser --all
> testuser_ior_id22-20-80229-14589323501426222819_1.darshan >&
> The above IOR benchmark is a read only benchmark to a shared file system,
> but the resulting darshan report indicates there are no READ operations?
> Any ideas why the resulting Darshan resport has no read operations? (Note
> if I add a -w option to the above IOR benchmark (i.e do a write and read
> to a shared filesystem, darshan only
> reports the writes and not reads?)
> Any help would be appreciated,
> Thanks for your support,
> Cormac.
> Darshan-users mailing list
> Darshan-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20181121/6e26dea7/attachment-0001.html>
More information about the Darshan-users
