[Darshan-users] About HPE MPI (MPT) support in Darshan (MPT ERROR: PMI2_Init)
pramod kumbhar pramod.s.kumbhar at gmail.com
Sat Jul 21 04:24:22 CDT 2018
Dear Kevin,
Sorry for delay in response. I looked into docs but couldn't find anything
specific. I tried:
$ srun -n 2
--export=LD_PRELOAD=/some_path/darshan-runtime-3.1.6-ryds66/lib/libdarshan.so,LD_LIBRARY_PATH=/opt/hpe/hpc/mpt/mpt-2.16/lib
./hello
srun: error: r2i0n34: task 1: Exited with exit code 255
 And core files doesn't say anything useful, its generated by slurm prolog:
warning: core file may not match specified executable file.
[New LWP 72075]
[New LWP 72080]
Core was generated by `/bin/bash /etc/slurm/slurm.taskprolog'.
Program terminated with signal 11, Segmentation fault.
#0  0x00002aaaac1cc1e1 in ?? ()
(gdb) bt
Python Exception <class 'gdb.MemoryError'> Cannot access memory at address
0x7fffffffddf8:
If I try to do :
$ LD_PRELOAD=/gpfs/
bbp.cscs.ch/data/project/proj16/kumbhar/soft/MPI_COMPARE/HPE_MPI/install/linux-rhel7-x86_64/intel-18.0.1/darshan-runtime-3.1.6-ryds66/lib/libdarshan.so
ls
Let me know if you have any suggestion to debug this further.
Pramod
On Thu, Jul 5, 2018 at 5:54 PM, Harms, Kevin <harms at alcf.anl.gov> wrote:
> Pramod,
>   are there ayn environment variables that can be set to print out what
> the error code is? Did you build libdarshan using the HP MPI?
> kevin
> From: Darshan-users <darshan-users-bounces at lists.mcs.anl.gov> on behalf
> of pramod kumbhar <pramod.s.kumbhar at gmail.com>
> Sent: Wednesday, July 4, 2018 7:54:21 AM
> To: darshan-users at lists.mcs.anl.gov
> Subject: [Darshan-users] About HPE MPI (MPT) support in Darshan (MPT
> ERROR: PMI2_Init)
> Dear All,
> I was trying to use Darshan (3.1.6) with HPE MPI (MPT)<
> https://support.hpe.com/hpsc/doc/public/display?docId=
> emr_na-a00037728en_us&docLocale=en_US> on our system and seeing below
> error:
> LD_PRELOAD=/gpfs/some_path/lib/libdarshan.so  srun -n 1
> /gpfs/some_another_path/bin/ior -a MPIIO -b 1G -t 4M  -c  -i 3
> With other MPI (e.g. intel-mpi), everything is working fine.
> Do you have any suggestions / workaround? Please let me know and I could
> help to debug/test the issue.
> Regards,
> Pramod
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20180721/ebd63be8/attachment.html>
More information about the Darshan-users mailing list
