[Darshan-users] About HPE MPI (MPT) support in Darshan (MPT ERROR: PMI2_Init)
Harms, Kevin harms at alcf.anl.gov
Thu Jul 5 10:54:38 CDT 2018
Pramod,
  are there ayn environment variables that can be set to print out what the error code is? Did you build libdarshan using the HP MPI?
kevin
From: Darshan-users <darshan-users-bounces at lists.mcs.anl.gov> on behalf of pramod kumbhar <pramod.s.kumbhar at gmail.com>
Sent: Wednesday, July 4, 2018 7:54:21 AM
To: darshan-users at lists.mcs.anl.gov
Subject: [Darshan-users] About HPE MPI (MPT) support in Darshan (MPT ERROR: PMI2_Init)
Dear All,
I was trying to use Darshan (3.1.6) with HPE MPI (MPT)<https://support.hpe.com/hpsc/doc/public/display?docId=emr_na-a00037728en_us&docLocale=en_US> on our system and seeing below error:
LD_PRELOAD=/gpfs/some_path/lib/libdarshan.so  srun -n 1 /gpfs/some_another_path/bin/ior -a MPIIO -b 1G -t 4M  -c  -i 3
With other MPI (e.g. intel-mpi), everything is working fine.
Do you have any suggestions / workaround? Please let me know and I could help to debug/test the issue.
Pramod
More information about the Darshan-users mailing list
