[Darshan-users] darshan3.1.5 issue on Cray XC40 cle6.up05
Phil Carns carns at mcs.anl.gov
Mon Feb 26 09:18:20 CST 2018
Hi Bilel,
Thanks for the bug report.  We can try to reproduce here and confirm.
In the mean time, can you tell me if the test_scalapack.f90 code is
using MPI or not?
thanks,
-Phil
On 02/24/2018 02:25 PM, Bilel Hadri wrote:
> Dear Darshan colleagues,
> I recently installed darshan 3.1.5 on Shaheen, Cray XC40, we recently
> upgraded the OS to CLE6.up05 and using the 17.12 PrgEnv.
> Compiling Scalapack with Cray Libsci fails with the error shown below
> with all programming environment. Similar issue was observed for other
> codes, like a simple petsc code.
> After digging, it seems that it is related to darshan3.1.5 version
> recently installed on Shaheen. When unloading darshan, the compilation
> works fine with no issue.
> The error is not appearing when using darshan 3.1.4.
> ftn -o exe test_scalapack.f90
> /opt/cray/dmapp/default/lib64/libdmapp.a(dmapp_internal.o): In
> function `_dmappi_is_pure_dmapp_job':
> /home/abuild/rpmbuild/BUILD/cray-dmapp-7.1.1/src/dmapp_internal.c:1401:
> undefined reference to `__wrap_MPI_Init'
> /opt/cray/pe/libsci/17.12.1/CRAY/8.6/x86_64/lib/libsci_cray_mpi_mp.a(blacs_exit_.o):
> In function `blacs_exit_':
> /b/worker/csml-libsci-sles/build/mp/scalapack/BLACS/SRC/blacs_exit_.c:42:
> undefined reference to `__wrap_MPI_Finalize'
> /opt/cray/pe/libsci/17.12.1/CRAY/8.6/x86_64/lib/libsci_cray_mpi_mp.a(blacs_pinfo_.o):
> In function `blacs_pinfo_':
> /b/worker/csml-libsci-sles/build/mp/scalapack/BLACS/SRC/blacs_pinfo_.c:18:
> /opt/cray/pe/libsci/17.12.1/CRAY/8.6/x86_64/lib/libsci_cray_mpi_mp.a(blacs_pinfo_.oo):
> In function `Cblacs_pinfo':
> /opt/cray/pe/cce/8.6.5/binutils/x86_64/x86_64-pc-linux-gnu/bin/ld:
> link errors found, deleting executable `exe'
> /usr/bin/sha1sum: exe: No such file or directory
> hadrib at cdl1:~>  ll /usr/bin/sha1
> sha1pass  sha1sum
> hadrib at cdl1:~>  ll /usr/bin/sha1sum
> -rwxr-xr-x 1 root root 43912 Aug  6  2016 /usr/bin/sha1sum
> hadrib at cdl1:~> which sha1sum
> /usr/bin/sha1sum
> hadrib at cdl1:~> module list
> Currently Loaded Modulefiles:
>   1) modules/3.2.10.6           9) pmi/5.0.13 17) atp/2.1.1
>   2) eproxy/2.0.22-6.0.5.0_2.1__g1ebe45c.ari        10)
> dmapp/7.1.1-6.0.5.0_49.8__g1125556.ari         18) perftools-base/7.0.0
>   3) cce/8.6.5         11)
> gni-headers/5.0.12-6.0.5.0_2.15__g2ef1ebc.ari  19) PrgEnv-cray/6.0.4
>   4) craype-network-aries         12)
> xpmem/2.2.4-6.0.5.0_4.8__g35d5e73.ari          20) cray-mpich/7.7.0
>   5) craype/2.5.13         13) job/2.2.2-6.0.5.0_8.47__g3c644b5.ari
>         21) slurm/slurm
>   6) cray-libsci/17.12.1         14)
> dvs/2.7_2.2.52-6.0.5.2_17.6__g5170dea          22) craype-haswell
>   7) udreg/2.3.2-6.0.5.0_13.12__ga14955a.ari        15)
> alps/6.5.28-6.0.5.0_18.6__g13a91b6.ari         23) texlive/2017
>   8) ugni/6.0.14-6.0.5.0_16.9__g19583bb.ari         16)
> rca/2.2.16-6.0.5.0_15.34__g5e09e6d.ari         24) darshan/3.1.5
> hadrib at cdl1:~> module swap PrgEnv-cray/6.0.4 PrgEnv-intel
> hadrib at cdl1:~> ftn -o exe_i test_scalapack.f90
> /opt/cray/pe/libsci/17.12.1/INTEL/16.0/x86_64/lib/libsci_intel_mpi.a(blacs_exit_.o):
> blacs_exit_.c:(.text+0xe9): undefined reference to `__wrap_MPI_Finalize'
> /opt/cray/pe/libsci/17.12.1/INTEL/16.0/x86_64/lib/libsci_intel_mpi.a(blacs_pinfo_.o):
> blacs_pinfo_.c:(.text+0x9b): undefined reference to `__wrap_MPI_Init'
> /opt/cray/pe/libsci/17.12.1/INTEL/16.0/x86_64/lib/libsci_intel_mpi.a(blacs_pinfo_.oo):
> hadrib at cdl1:~>
> hadrib at cdl1:~>
> hadrib at cdl1:~> module swap PrgEnv-intel/6.0.4 PrgEnv-gnu
> PrgEnv-gnu        PrgEnv-gnu/6.0.4
> /opt/cray/pe/libsci/17.12.1/GNU/6.1/x86_64/lib/libsci_gnu_61_mpi.a(blacs_exit_.o):
> blacs_exit_.c:(.text+0xdb): undefined reference to `__wrap_MPI_Finalize'
> /opt/cray/pe/libsci/17.12.1/GNU/6.1/x86_64/lib/libsci_gnu_61_mpi.a(blacs_pinfo_.o):
> blacs_pinfo_.c:(.text+0xb3): undefined reference to `__wrap_MPI_Init'
> /opt/cray/pe/libsci/17.12.1/GNU/6.1/x86_64/lib/libsci_gnu_61_mpi.a(blacs_pinfo_.oo):
> implicit none
> integer :: n, nb    ! problem size and block size
> integer :: myunit   ! local output unit number
> integer :: myArows, myAcols   ! size of local subset of global array
> integer :: i,j, igrid,jgrid, iproc,jproc, myi,myj, p
> real*8, dimension(:,:), allocatable :: myA,myB,myC
> integer :: numroc   ! blacs routine
> integer :: me, procs, icontxt, prow, pcol, myrow, mycol  ! blacs data
> integer :: info    ! scalapack return value
> integer, dimension(9)   :: ides_a, ides_b, ides_c ! scalapack array desc
> open(unit=1,file="ABCp.dat",status="old",form="formatted")
> read(1,*)prow
> read(1,*)pcol
> read(1,*)n
> read(1,*)nb
> close(1)
> if (((n/nb) < prow) .or. ((n/nb) < pcol)) then
> print *,"Problem size too small for processor set!"
> stop 100
> endif
> call blacs_pinfo   (me,procs)
> call blacs_get     (0, 0, icontxt)
> call blacs_gridinit(icontxt, 'R', prow, pcol)
> call blacs_gridinfo(icontxt, prow, pcol, myrow, mycol)
> myunit = 10+me
> write(myunit,*)"--------"
> write(myunit,*)"Output for processor ",me," to unit ",myunit
> write(myunit,*)"Proc ",me,": myrow, mycol in p-array is ", &
> myrow, mycol
> myArows = numroc(n, nb, myrow, 0, prow)
> myAcols = numroc(n, nb, mycol, 0, pcol)
> write(myunit,*)"Size of global array is ",n," x ",n
> write(myunit,*)"Size of block is ",nb," x ",nb
> write(myunit,*)"Size of local array is ",myArows," x ",myAcols
> allocate(myA(myArows,myAcols))
> allocate(myB(myArows,myAcols))
> allocate(myC(myArows,myAcols))
> do i=1,n
> call g2l(i,n,prow,nb,iproc,myi)
> if (myrow==iproc) then
> do j=1,n
> call g2l(j,n,pcol,nb,jproc,myj)
> if (mycol==jproc) then
> myA(myi,myj) = real(i+j)
> myB(myi,myj) = real(i-j)
> myC(myi,myj) = 0.d0
> endif
> enddo
> endif
> enddo
> ! Prepare array descriptors for ScaLAPACK
> ides_a(1) = 1         ! descriptor type
> ides_a(2) = icontxt   ! blacs context
> ides_a(3) = n         ! global number of rows
> ides_a(4) = n         ! global number of columns
> ides_a(5) = nb        ! row block size
> ides_a(6) = nb        ! column block size
> ides_a(7) = 0         ! initial process row
> ides_a(8) = 0         ! initial process column
> ides_a(9) = myArows   ! leading dimension of local array
> do i=1,9
> ides_b(i) = ides_a(i)
> ides_c(i) = ides_a(i)
> enddo
> ! Call ScaLAPACK library routine
> call pdgemm('T','T',n,n,n,1.0d0, myA,1,1,ides_a,  &
> myB,1,1,ides_b,0.d0, &
> myC,1,1,ides_c )
> ! Print results
> call g2l(n,n,prow,nb,iproc,myi)
> call g2l(n,n,pcol,nb,jproc,myj)
> if ((myrow==iproc) .and. (mycol==jproc)) &
> write(*,*) 'c(',n,n,')=',myC(myi,myj)
> ! Deallocate the local arrays
> deallocate(myA, myB, myC)
> ! End blacs for processors that are used
> call blacs_gridexit(icontxt)
> call blacs_exit(0)
> end
> ! convert global index to local index in block-cyclic distribution
> subroutine g2l(i,n,np,nb,p,il)
> implicit none
> integer :: i    ! global array index, input
> integer :: n    ! global array dimension, input
> integer :: np   ! processor array dimension, input
> integer :: nb   ! block size, input
> integer :: p    ! processor array index, output
> integer :: il   ! local array index, output
> integer :: im1
> im1 = i-1
> p   = mod((im1/nb),np)
> il  = (im1/(np*nb))*nb + mod(im1,nb) + 1
> return
> end
> ! convert local index to global index in block-cyclic distribution
> subroutine l2g(il,p,n,np,nb,i)
> implicit none
> integer :: il   ! local array index, input
> integer :: p    ! processor array index, input
> integer :: i    ! global array index, output
> integer :: ilm1
> ilm1 = il-1
> i    = (((ilm1/nb) * np) + p)*nb + mod(ilm1,nb) + 1
> return
> end
> Bilel Hadri, PhD
> Computational Scientist
> KAUST Supercomputing Lab
> Al Khawarizmi Bldg. (1)  Office 126
> 4700 King Abdullah University of Science and Technology
> Thuwal 23955-6900
> Kingdom of Saudi Arabia
> Office Phone: +966 12 808 0654
> Cell Phone: + 966 544 700 893
> This message and its contents including attachments are intended
> solely for the original recipient. If you are not the intended
> recipient or have received this message in error, please notify me
> immediately and delete this message from your computer system. Any
> unauthorized use or distribution is prohibited. Please consider the
> environment before printing this email.
> Darshan-users mailing list
> Darshan-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20180226/f2556176/attachment-0001.html>
More information about the Darshan-users mailing list
