[Darshan-users] DXT parser issues
Shane Snyder ssnyder at mcs.anl.gov
Mon Feb 20 17:03:20 CST 2017
Hi James,
This was a bug in the darshan-parser utility, so not related to anything
you are doing. It has since been fixed in Darshan's master branch, and
we will try to roll it up into a point release in the next couple of days.
I will note that darshan-parser should still be able to print all of the
data in the darshan log (it just crashes when it reaches the DXT data
stored at the very end), if that is any consolation.
Thanks a bunch for reporting the bug to us!
--Shane
On 02/17/2017 04:59 AM, James Dickson wrote:
> Hi,
> I'm having some issues parsing the output file generated with DXT
> enabled.
> When using the darshan-parser utility, I'm getting a seg fault upon
> reaching the DXT_POSIX module, which is coming from line 482 in the
> darshan-parser code according to gdb. However, if I use the
> darshan-dxt-parser it gets through the file no problem.
> Is this a problem with the parser or some quirk of my trace file?
> Many thanks,
> James
> Darshan-users mailing list
> Darshan-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20170220/96db24ed/attachment.html>
More information about the Darshan-users mailing list
