[Darshan-users] compiling statically with intel toolchain
Salmon, Rene salmr0 at bp.com
Mon May 23 14:46:31 CDT 2016
Hi Phil,
Thanks for the info that was helpful.  I did manage to link in darshan and MPI statically I had to put in the “lib.a” files by hand as the “darshan-config –pre/post” scripts where still trying to link in darshan dynamically.
Here is the link line I used that seem to generate a binary.
mpiifort  -DLinux -Dx86_64 -DINTEL -DCompLevel16 -DX86_64 -D__x86_64__ -static-intel -static_mpi -DOpenMP -openmp -DSWAP -O3 -g -o /hpcdata/salmr0/mspain/usp2hdf5/dds/bin/Linux/3.0/x86_64/ddswriter.revUnversioned /hpc/tstapps/intel/x86_64/ics-2016.update.1/compilers_and_libraries_2016.1.150/linux/mpi/intel64/lib/libmpifort.a -L/hpc/tstapps/SLES/3.0/x86_64/darshan/3.0.0/lib /hpc/tstapps/SLES/3.0/x86_64/darshan/3.0.0/lib/libdarshan.a -lz -Wl,@/hpc/tstapps/SLES/3.0/x86_64/darshan/3.0.0/share/ld-opts/darshan-base-ld-opts svn_version.o PartitionLayout_mod.o ddswriter.o -L/tstapps/asi/src/dds/lib/Linux/3.0/x86_64/Intel-16.0.1.150MPI5.1.2MKL11.3.1 -ldds_r3 -lgio -lfhost -L/hpc/tstapps/SLES/3.0/x86_64/darshan/3.0.0/lib -Wl,--start-group /hpc/tstapps/SLES/3.0/x86_64/darshan/3.0.0/lib/libdarshan.a /hpc/tstapps/SLES/3.0/x86_64/darshan/3.0.0/lib/libdarshan-stubs.a -Wl,--end-group -lz
Here is what the binary look like:
hpcbuild02(salmr0)1181:ldd bin/Linux/3.0/x86_64/ddswriter
	linux-vdso.so.1 =>  (0x00007ffe791a7000)
	libz.so.1 => /lib64/libz.so.1 (0x00002aafaab7c000)
	libdl.so.2 => /lib64/libdl.so.2 (0x00002aafaad92000)
	librt.so.1 => /lib64/librt.so.1 (0x00002aafaaf96000)
	libpthread.so.0 => /lib64/libpthread.so.0 (0x00002aafab1a0000)
	libm.so.6 => /lib64/libm.so.6 (0x00002aafab3bd000)
	libc.so.6 => /lib64/libc.so.6 (0x00002aafab636000)
	/lib64/ld-linux-x86-64.so.2 (0x00002aafaa95a000)
	libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00002aafab9b3000)
hpcbuild02(salmr0)1182:nm bin/Linux/3.0/x86_64/ddswriter|grep darshan
0000000000482e90 T darshan_clean_file_path
0000000000483210 t darshan_common_val_compare
00000000004830c0 T darshan_common_val_counter
00000000004831a0 t darshan_common_val_walker
000000000101e860 b darshan_core
0000000000463f50 t darshan_core_cleanup
00000000004655e0 T darshan_core_initialize
0000000000fcfa80 d darshan_core_mutex
0000000000464720 T darshan_core_register_module
0000000000464b80 T darshan_core_register_record
0000000000461c10 T darshan_core_shutdown
0000000000464840 T darshan_core_unregister_module
0000000000465310 T darshan_core_unregister_record
00000000004655b0 T darshan_core_wtime
0000000000463e40 t darshan_deflate_buffer..0
00000000004642b0 t darshan_get_shared_records
00000000004806a0 T darshan_hash
0000000000fcfab0 d darshan_mem_alignment
0000000000fcfaec d darshan_mem_alignment
0000000000b64848 r darshan_module_names
0000000000b6487c r darshan_module_versions
0000000000479ae0 T darshan_mpiio_shutdown_bench_setup
0000000000fcfa20 D darshan_path_exclusions
0000000000470250 T darshan_posix_shutdown_bench_setup
0000000000461750 T darshan_shutdown_bench
0000000000483230 T darshan_variance_reduce
0000000000483170 T darshan_walk_common_vals
The problem I am having now is that I don’t get a darshan log file when I run my executable. I configured darshan with this configure flag “--with-log-path-by-env=DARSHANLOGPATH”.  I set that environment variable in my shell to some directory and then run my executable.  The executable runs fine but no darshan log file gets generated.
Any ideas?   Thanks in advanced.
Rene
On 5/20/16, 7:33 AM, "darshan-users-bounces at lists.mcs.anl.gov on behalf of Phil Carns" <darshan-users-bounces at lists.mcs.anl.gov on behalf of carns at mcs.anl.gov> wrote:
>Hi Rene,
>Does mpiifort support the "-show" option (or something similar) to
>display the underlying link command that it is using?
>I can describe the manual steps needed to add Darshan support just to
>see if you can get it working, and then we can maybe circle back to why
>the Darshan-generated script is triggering dynamic linking.  In general,
>there are two sets of extra link flags that Darshan needs to add to the
>link command.  Some should appear before the user-specified libraries in
>the true link command, some should appear after them.  On my test box
>they happen to look like this:
>pcarns at carns-x1:~/working/install/bin$ darshan-config --pre-ld-flags
>-L/home/pcarns/working/install/lib -ldarshan -lz
>-Wl,@/home/pcarns/working/install/share/ld-opts/darshan-base-ld-opts
>pcarns at carns-x1:~/working/install/bin$ darshan-config --post-ld-flags
>-L/home/pcarns/working/install/lib -Wl,--start-group -ldarshan
>-ldarshan-stubs -Wl,--end-group -lz -lrt -lpthread
>On most MPI implementations there is also one more library that you have
>to add for MPI function wrapping to work.  Darshan-config doesn't add
>that because it is dependent on the MPI implementation. On most versions
>of MPI this is either -lmpifort or -lfmpich.  I'm not sure which one
>Intel MPI uses now.
>You might be able to do all of that external to mpiifort, but I'm not
>sure.  If so, then your link command would look something like this
>(possibly swapping out -lmpifort for -lfmpich or omitting it entirely):
>mpiifort -DLinux -Dx86_64 -DINTEL -DCompLevel16 -DX86_64 -D__x86_64__ -static-intel -static_mpi -DOpenMP -openmp -DSWAP -O3 -g -o ./ddswriter.revUnversioned -lmpifort `darshan-config --pre-ld-flags` PartitionLayout_mod.o ddswriter.o -L/tstapps/asi/src/dds/lib/Linux/3.0/x86_64/Intel-16.0.1.150MPI5.1.2MKL11.3.1 -ldds_r3 -lgio -lfhost `darshan-config --post-ld-flags`
>If that doesn't work then you'll need to find out what the underlying
>link command looks like (via -show or similar) and insert it there.
>thanks,
>-Phil
More information about the Darshan-users mailing list
