[Darshan-users] Darshan I/O profiling of sequential code
Phil Carns carns at mcs.anl.gov
Wed Dec 14 10:11:32 CST 2016
Hi Wadud,
For most (but not all) MPI implementations you wouldn't even need to use
mpirun.  You can just launch the program like you normally would with
./app.exe and the MPI library will assume that it is operating in a
single-process environment.
-Phil
On 12/14/2016 11:02 AM, Wadud Miah wrote:
> Hi Shane,
> Thanks for the quick reply. I will probably just enclose the
> sequential code using MPI_INIT() and MPI_FINALIZE() and execute it
> using mpirun -n 1 ./app.exe. Do you think that will work?
> Regards,
> Wadud.
> *From:*Shane Snyder [mailto:ssnyder at mcs.anl.gov]
> *Sent:* 14 December 2016 15:57
> *To:* Wadud Miah <wadud.miah at nag.co.uk>; darshan-users at lists.mcs.anl.gov
> *Subject:* Re: [Darshan-users] Darshan I/O profiling of sequential code
> Hi Wadud,
> Right now, Darshan can only instrument MPI applications. It intercepts
> MPI_Init and MPI_Finalize to initialize itself and to produce the
> output log file, respectively. It also uses MPI communication and I/O
> operations at shutdown time to aggregate data across all processes and
> write to the log file. Breaking the MPI dependencies isn't exactly
> straightforward, but we have at least been thinking about how to
> extend Darshan to non-MPI codes. Recent changes to the architecture
> have been a step in the right direction but there's still work to do
> to get us all the way there.
> We will continue to think about this and will certainly keep the
> mailing list updated with any progress we make.
> Thanks,
> --Shane
> On 12/14/2016 09:35 AM, Wadud Miah wrote:
>     Hello,
>     I have built Darshan using Intel MPI (2017) and would like to
>     profile a sequential code using Darshan. I have used the same
>     Darshan library to profile an MPI code it works fine. I execute
>     the following command line for a sequential code :
>     $ export DARSHAN_LOGPATH=.
>     LD_PRELOAD=/home/pr1ebt00/pr1ebt05/darshan-3.1.2-impi/lib/libdarshan.so
>     ~/gbmoldd/utilities/joinfiles.exe
>     but it doesn’t create any Darshan output file. Do you know if I
>     can profile sequential codes using Darshan? If so, how can I do this?
>     Best regards,
>     Wadud.
>     Dr. Wadud Miah
>     Computational Scientist
>     Numerical Algorithms Group
>     01865 518035
>     The Numerical Algorithms Group Ltd is a company registered in
>     England and Wales with company number 1249803. The registered
>     office is:
>     Wilkinson House, Jordan Hill Road, Oxford OX2 8DR, United Kingdom.
>     This e-mail has been scanned for all viruses by Microsoft Office 365.
>     _______________________________________________
>     Darshan-users mailing list
>     Darshan-users at lists.mcs.anl.gov
>     <mailto:Darshan-users at lists.mcs.anl.gov>
>     https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
> ________________________________________________________________________
> This e-mail has been scanned for all viruses by Star.
> The Numerical Algorithms Group Ltd is a company registered in England
> and Wales with company number 1249803. The registered office is:
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20161214/f02cf8fa/attachment-0001.html>
More information about the Darshan-users mailing list
