[Darshan-users] No PDF file generation with darshan-summary-per-file.sh or darshan-job-summary.pl utility
Suman, Preeti
preeti.suman at intel.com
Sun Sep 6 22:07:13 CDT 2015
I have recently started working with Darshan 2.3.1 on my system. I have installed all the prerequisites: Perl, pdflatex, epstopdf, and gnuplot to enable darshan-job-summary.pl utility. I have few questions specified below regarding the use of darshan-summary-per-file.sh and darshan-job-summary.pl.
System specification:
Kernel Version: Linux 4.0.5-1.el7.elrepo.x86_64
Operating System: CentOS Linux release 7.1.1503
CPU: Intel(R) Xeon(R) CPU E5-2630 v3 @ 2.40GHz (Haswell-EP)
Architecture:x86_64
Compiler: GCC 5.1.0
MPI: Intel MPI
#### BEGIN : output of darshan-summary-per-file.sh
$ darshan-summary-per-file.sh carns_mpi-io-test-ppc64-2.3.1_id426989_3-13-61875-4723177368895607730_1.darshan.gz ../output
Status: Generating summary for file 1 of 1: mpi-io-test.dat
Slowest unique file time: 0
Slowest shared file time: 0.190554
Total bytes read and written by app (may be incorrect): 33554432
Total absolute I/O time: 0.190554
LaTeX generation (phase1) failed [256], aborting summary creation.
error log:
or enter new name. (Default extension: sty)
Enter file name:
! Emergency stop.
<read *>
l.8 \usepackage
{multirow}^^M
! ==> Fatal error occurred, no output PDF file produced!
Transcript written on summary.log.
darshan-summary-per-file.sh done. Results can be found in /nfs/fx/proj/coralhpctools/users/psuman/myBuilds/Darshan/gcc/0904_logs/out1/*.pdf.
#### END: darshan-summary-per-file.sh
I am using the few benchmarks and darshan-test/example-output files to test the installation. There is no PDF file generation while running the darshan-summary-per-file.sh or darshan-job-summary.pl utility. Here are few questions:
a) Is the error message of darshan-summary-per-file.sh utility mentioned above linked to Darshan or PDFLatex?
b) Is there any other dependency needed to enable darshan-summary-per-file.sh and other utilities?
c) If this is not a dependency error, What could be the reason for the error?
Will greatly appreciate your response.
Preeti
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20150907/8903aab8/attachment.html>
More information about the Darshan-users
