[Darshan-users] Darshan unable to write log files
Phil Carns carns at mcs.anl.gov
Thu Feb 26 16:19:04 CST 2015
On 02/26/2015 04:54 PM, Latham, Robert J. wrote:
> On 02/26/2015 03:16 PM, Gunter, David O wrote:
>> Good call, Rob. Thanks!
>> Saving to a non-Panasas directory worked, as did writing to Panasas with the ufs: prefix.
> Ok, super strange.  When darshan writes the log files, it does it
> through MPI-IO, so if one can write via MPI-IO to your panasass file
> system, why can't darshan?
The only unusual thing that I can think of in Darshan's log-writing path
is that it sets a few MPI-IO hints.  Specifically, it uses this by
default:  "romio_no_indep_rw=true;cb_nodes=4".  That triggers the use of
deferred opens and limits the number of aggregators to 4.
You could try turning those hints off by setting the
CP_LOG_HINTS_OVERRIDE="" environment variable before running your
application (and of course aiming the logs at your Panasas volume
without using a ufs: prefix).
Those hints should be harmless in theory, but it might be worth a shot.
thanks,
-Phil
> the error "MPI_ERR_IO: input/output error" is not very helpful.  It's
> the error you get if it was not ENAMETOOLONG, ENOENT, ENOTDIR, ELOOP,
> EACCES, EROFS.
> Last summer I commited some code to ROMIO to also catch EDQUOT, ENOSPC,
> and EEXIST.
> But even in the "all other cases" case, ROMIO's supposed to call
> strerror() and give you something -- anything! -- more helpful than "Uh,
> some IO error happened"
> What MPI implementation are you using?
> ==rob
>> -david
>> David Gunter
>> HPC-5: Applications Readiness Team
>>> On Feb 26, 2015, at 2:04 PM, Rob Latham <robl at mcs.anl.gov> wrote:
>>> On 02/26/2015 02:54 PM, Gunter, David O wrote:
>>>> My app writes to a Panasas file system, /scratch/dog/test_prob and I have set
>>>> DARSHAN_LOGPATH to /scratch/dog/darshan_logs/
>>> this bit, about Panasas, is the only thing that looks out of the ordinary to me.
>>> Can you try a non-panasas file system?  If not, can you try prefixing the file with ufs: (DARSHAN_LOGPATH=ufs:/scratch/dog/darshan_logs/
>>> Did you set up the year/month/day directories?
>>> (darshan-runtime/darshan-mk-log-dirs.pl )
>>> ==rob
>>>> The permissions on the directory are good. My mpi job runs to completion and then I get the error message.
>>>> $ mpirun -n 16 ./higrad_driver_noCBE ./params.16pe.in
>>>> Total time for simulation = 69.468311
>>>> HiGrad simulation is complete!!
>>>> Shutting down MPI environment!
>>>> darshan library warning: unable to open log file /scratch/dog/darshan_logs/dog_higrad_driver_noCBE_id501442_2-26-49816-14771330631875741401.darshan_partial: MPI_ERR_IO: input/output error
>>>> darshan library warning: unable to write log file /scratch/dog/darshan_logs/dog_higrad_driver_noCBE_id501442_2-26-49816-14771330631875741401.darshan_partial
>>>> David Gunter
>>>> _______________________________________________
>>>> Darshan-users mailing list
>>>> Darshan-users at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
>>> Rob Latham
>>> Mathematics and Computer Science Division
>>> Argonne National Lab, IL USA
More information about the Darshan-users mailing list
