[Darshan-users] Darshan unable to write log files
Shane Snyder
ssnyder at mcs.anl.gov
Thu Feb 26 15:18:18 CST 2015
On 02/26/2015 03:04 PM, Rob Latham wrote:
> On 02/26/2015 02:54 PM, Gunter, David O wrote:
>> My app writes to a Panasas file system, /scratch/dog/test_prob and I
>> have set
>> DARSHAN_LOGPATH to /scratch/dog/darshan_logs/
> this bit, about Panasas, is the only thing that looks out of the
> ordinary to me.
> Can you try a non-panasas file system? If not, can you try prefixing
> the file with ufs: (DARSHAN_LOGPATH=ufs:/scratch/dog/darshan_logs/
> Did you set up the year/month/day directories?
> (darshan-runtime/darshan-mk-log-dirs.pl )
Just a heads up, but by specifying the '--with-log-path-by-env'
configure option, Darshan won't attempt to write to a directory of the
structure year/month/day. It will write the log file directly to the
directory given in DARSHAN_LOGPATH in this case. So, that at least
doesn't appear to be the problem.
--Shane
> ==rob
>> The permissions on the directory are good. My mpi job runs to
>> completion and then I get the error message.
>> $ mpirun -n 16 ./higrad_driver_noCBE ./params.16pe.in
>> Total time for simulation = 69.468311
>> HiGrad simulation is complete!!
>> Shutting down MPI environment!
>> darshan library warning: unable to open log file
>> /scratch/dog/darshan_logs/dog_higrad_driver_noCBE_id501442_2-26-49816-14771330631875741401.darshan_partial:
>> MPI_ERR_IO: input/output error
>> darshan library warning: unable to write log file
>> David Gunter
>> HPC-5: Applications Readiness Team
>> Darshan-users mailing list
>> Darshan-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
More information about the Darshan-users
