[Darshan-users] darshan-3.0.0-pre3 point release
    Shane Snyder
    ssnyder at mcs.anl.gov
    Fri Dec 11 17:30:19 CST 2015
Darshan users,
There is a new point release attached for the modularized 3.0.0 version
of Darshan. This point release contains the following changes:
* add module-specific version fields to header to allow utilities to
handle different versions of a module’s I/O data for backwards
compatibility — NOTE: this breaks the log file parsing for logs obtained
using Darshan-3.0.0-pre2 & Darshan-3.0.0-pre1
* bug fix in regression test scripts for setting proper environment
variables to use MPI profiling configuration for Fortran apps
* bug fix in bzip2 log writing implementation in darshan-logutils
* possible race conditions resolved in each module’s shutdown code
* general code, comment, and documentation cleanup
* addition of module-specific counter descriptions printed prior to
parsing a modules I/O data in darshan-parser
As a reminder, this is still an experimental release and is *not*
appropriate for production use at the moment, though we are getting
close to an official release! We hope you can take the time to try the
new version in preparation for the upcoming release, and look forward to
any feedback you may have.
Documentation for this version of Darshan can be found HERE
<http://press3.mcs.anl.gov/darshan/documentation/>, under the Darshan
3.0.0 heading.
Thank you!
--Darshan team
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20151211/b7e9d049/attachment-0001.html>
Type: application/gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20151211/b7e9d049/attachment-0001.bin>
More information about the Darshan-users
