[Darshan-users] DARSHAN and Open MPI
    David Shrader
    dshrader at lanl.gov
    Wed Mar  6 14:56:34 CST 2013
Hello Phil,
Thank you for the quick reply! That stack trace on the Darshan list is
eerily like the one I have...
I just used Open MPI 1.6.4 and it works for me and the application I'm
using. Thanks again!
David
On 03/06/2013 11:01 AM, Phil Carns wrote:
> On 03/06/2013 12:41 PM, David Shrader wrote:
>> Hello All,
>> I have DARSHAN working with our mvapich2 1.8 GNU installation and am
>> trying to get it to work with a GNU build of Open MPI 1.6.3. The
>> building of DARSHAN completes without a problem when I point it to a
>> mpicc that is owned by Open MPI 1.6.3, but when I try to run an
>> application compiled with Open MPI 1.6.3, I get a seg fault. I know,
>> from reading the documentation, that DARSHAN seems to work easier
>> with MPICH derivatives; that being said, are there any known issues
>> and/or workarounds with trying to use Open MPI? Right now I am using
>> a TOSS2 machine with dynamic linking (I currently can't do static
>> linking due to a missing static version of a system library).
>> Thank you!
>> David
> Yes, there is actually a known issue with Darshan and LD_PRELOAD on
> some versions of OpenMPI.  You have two options:
> a) update to OpenMPI 1.6.4
> b) apply the attached patch to Darshan (this is a workaround, only
> tested with OpenMPI 1.6.3)
> For some more information on why Darshan won't LD_PRELOAD correctly on
> OpenMPI 1.6.3, you can have a look at these mailing list threads from
> each project:
>    http://www.open-mpi.org/community/lists/devel/2013/01/11917.php
> http://lists.mcs.anl.gov/pipermail/darshan-users/2013-January/000128.html
> I'll make a note to add this to the documentation; I should have done
> that in the last Darshan release.
> -Phil
> Darshan-users mailing list
> Darshan-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
David Shrader
SICORP, Inc
1350 Central Ave
Suite 104
Los Alamos, NM 87544
David.Shrader at SICORP.com
LANL contact information:
LANL #: 505-664-0996
LANL email: dshrader at lanl.gov
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20130306/af06c0d8/attachment.html>
More information about the Darshan-users
