[Darshan-users] no write information when using mvapich2
David Shrader dshrader at lanl.gov
Fri Jul 19 12:06:42 CDT 2013
Hello All,
I am currently trying to bring up a Darshan build that supports mvapich2
1.7 and 1.8. The build seemingly completes without an issue, but I have
noticed a problem when running an IO-replication application that we
like to use: I am getting no stats in terms of writes. The app's general
flow is to do a writing phase and then a reading phase to a single file
(no collective operations except when opening the file). The stats for
the reading phase are about what I expect. However, the stats for the
writes are all 0. Specifically, CP_BYTES_WRITTEN and CP_POSIX_WRITES are
both 0. The corresponding READS counters are where they should be.
I have tested this app (with the same run command) using a build of
Darshan that works with Open MPI. There, the WRITE-related counters I
mentioned above are where I expect them to be. It is just the mvapich2
builds that have this behavior.
Did I miss something when building for mvapich2? Any ideas as to why
write information might be missing? If it helps, I can send some of the
output from darshan-parser (there is only a single file being written
to, so the output isn't that large) or the log file itself.
David
David Shrader
SICORP, Inc
1350 Central Ave
Suite 104
Los Alamos, NM 87544
David.Shrader at SICORP.com
LANL contact information:
LANL #: 505-664-0996
LANL email: dshrader at lanl.gov
More information about the Darshan-users mailing list
