[Darshan-users] Instrumenting statically-linked applications
Dragos Constantin dragos.constantin at stanford.edu
Mon Nov 26 14:27:17 CST 2012
Hi Kevin,
The problem is not with the argument parsing. This is what I get in both cases:
login4$ ./darshan-gen-cc.pl /opt/apps/gcc4_4/mvapich/1.0.1/bin/mpicc --output mpicc.darshan
CC_from_link = gcc -Wl,-rpath,/opt/apps/gcc4_4/mvapich/1.0.1/lib/shared -Wl,-rpath-link -Wl,/opt/apps/gcc4_4/mvapich/1.0.1/lib/shared -L/opt/apps/gcc4_4/mvapich/1.0.1/lib/shared -L/opt/apps/gcc4_4/mvapich/1.0.1/lib
CC_from_compile = gcc
Error: cannot find matching CC from: gcc -c foo.c -I/opt/apps/gcc4_4/mvapich/1.0.1/include
and: gcc -Wl,-rpath,/opt/apps/gcc4_4/mvapich/1.0.1/lib/shared -Wl,-rpath-link -Wl,/opt/apps/gcc4_4/mvapich/1.0.1/lib/shared -L/opt/apps/gcc4_4/mvapich/1.0.1/lib/shared -L/opt/apps/gcc4_4/mvapich/1.0.1/lib foo.o -o foo -lmpich -L/opt/ofed//lib64/ -libverbs -libumad -lpthread -lpthread -lrt
login4$ ./darshan-gen-cc.pl --output mpicc.darshan /opt/apps/gcc4_4/mvapich/1.0.1/bin/mpicc
As you can see:
but CC_from_link is not gcc and if I am not mistaken it should be gcc. I just started to look at the script and you might know better what is going on here.
Dragos
Dragos Constantin, PhD
Research Associate
Department of Radiology
Stanford University
Lucas MRS Center
1201 Welch Rd., PS-055
Stanford CA 94305
Office: (650) 736-9961
Fax: (650) 723-5795
----- Original Message -----
To: "Dragos Constantin" <dragos.constantin at stanford.edu>
Cc: darshan-users at lists.mcs.anl.gov
Sent: Monday, November 26, 2012 12:23:00 PM
Subject: Re: [Darshan-users] Instrumenting statically-linked applications
  I think this might be a simple issue with argument parsing. Try this instead:
kevin
On Nov 26, 2012, at 2:16 PM, Dragos Constantin wrote:
> Hi,
> I've installed and configured darshan-2.2.3 on TACC Ranger in my user space. I have used gcc-4.4.5 (and mvapich-1.0.1).
> When I try to generate the MPI compiler scripts for statically-linked applications I get the following error:
> I am not quite sure what triggered this. Any ideas how to quickly fix the issue? I will look at the perl script to see what is going on there.
> Thanks,
> Dragos
> Research Associate
> Stanford University
> Lucas MRS Center
> Stanford CA 94305
> Fax: (650) 723-5795
> Darshan-users mailing list
> Darshan-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
More information about the Darshan-users mailing list
