[Darshan-users] Darshan and Intel MPI (x86_64)
Phil Carns carns at mcs.anl.gov
Mon Feb 20 12:44:15 CST 2012
I don't have any first-hand experience with Intel MPI, but in principle
it should work.
Does your MPI compiler produces dynamic executables by default?  If so,
can you try leaving your executable/binary unmodified and load the
libdarshan.so library at runtime using the LD_PRELOAD environment
variable, rather than directly linking it to your application?  There is
some more detail about this approach on this page:
http://wiki.mcs.anl.gov/Darshan/index.php/Dynamic_linking
thanks,
-Phil
On 02/20/2012 01:28 PM, Harr, Cameron Contractor, SAIC wrote:
> I'm trying to get Darshan running on a RedHat/X86_64 cluster with a
> few different flavors of MPI available. I'm most recently trying Intel
> MPI and gfortran (Intel Compilers didn't seem to work) and after a
> fair bit of tweaking, got the executable recompiled with libdarshan.so
> successfully linked in. In my job run script, I verify that libdarshan
> is linked in and the job runs to completion; however no output is
> generated. I also tried setting DARSHAN_INTERNAL_TIMING=1, but still
> no output. Should I be able to use Intel MPI and/or is there a place
> that documents which MPI stacks are supported?
> _____________________
> *Cameron Harr *| SAIC | C4IT BU
> Systems Analyst | FNMOC
> phone:  831.656.4154
> mobile: 831.233.8216
> email: cameron.harr.ctr at navy.mil
> email: harrc at saic.com
> Darshan-users mailing list
> Darshan-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20120220/29886ae8/attachment.htm>
More information about the Darshan-users mailing list
