[Darshan-users] A bug report and a feature request
Rob Latham
robl at mcs.anl.gov
Thu Sep 15 12:56:35 CDT 2011
On Thu, Sep 15, 2011 at 01:34:33PM -0400, Phil Carns wrote:
> On 09/15/2011 01:17 PM, Bill Barth wrote:
> >The Bug Report:
> >I think that the summary.pdf has swapped the summaries for read and write
> >in the "Data Transfer Per Filesystem" table. I'm happy to share a logfile
> >if you can't reproduce on your end.
> That would be great if you could send us a log file example. I just
> tried a quick test on an old log file and it looked Ok in that
> particular case. It might depend on the contents of the log.
> >The Feature Request:
> >darshan-job-summary.pl should produce its output pdf file based on the
> >name of the input logfile rather than calling it "summary.pdf".
> We could probably add a command line option to produce that
> behavior. In the mean time you can at least use the --output option
> to specify the file name.
I've started looking at how to make the tool output one summary file
per program data file (motivating case study: visualization tools read
one set of input data and write a separate output file -- two distinct
workloads).
==rob
Rob Latham
Mathematics and Computer Science Division
Argonne National Lab, IL USA
More information about the Darshan-users
