[Darshan-users] darshan output from log
Phil Carns
carns at mcs.anl.gov
Wed May 25 05:25:44 CDT 2011
Great! I'm glad to hear that it is working.
-Phil
On 05/24/2011 11:15 PM, ketan wrote:
> Sorry, I meant: I installed gnuplot from source and put its bin in PATH!
> On 5/24/11 10:12 PM, ketan wrote:
>> Thanks Phil,
>> I installed gnuplot from source and put its bin in bin. That did the
>> trick.
>> Ketan
>> On 5/24/11 8:41 PM, Phil Carns wrote:
>>> Hi Ketan,
>>> You need a newer version of gnuplot. If you download the source
>>> from the gnuplot web site and compile it, you can just copy the
>>> resulting gnuplot binary to the ~/darshan-install/bin/ directory and
>>> darshan-job-summary.pl will automatically detect it and use it in
>>> place of the default gnuplot installed on the system.
>>> -Phil
>>> On 05/24/2011 07:34 PM, ketan wrote:
>>>> Hi,
>>>> I tried to copy the share folder manually from darshan source tree
>>>> to darshan-install. Now I get a better output yet the pdf file
>>>> generation is not complete.
>>>> [login.ci.uchicago.edu:24]$
>>>> ~/darshan-install/bin/darshan-job-summary.pl
>>>> ketan_modftdock_id9643_5-24-42129-16735182948803816265_1.darshan.gz
>>>> --output ~/job-summary.pdf
>>>> Slowest unique file time: 0
>>>> Slowest shared file time: 0.058647
>>>> Total bytes read and written by app (may be incorrect): 243
>>>> Total absolute I/O time: 0.058647
>>>> gnuplot> set style data histogram
>>>> "counts-eps.gplt", line 7: expecting 'lines', 'points',
>>>> 'linespoints', 'dots', 'impulses',
>>>> 'yerrorbars', 'xerrorbars', 'xyerrorbars', 'steps', 'fsteps',
>>>> 'histeps', 'filledcurves', 'boxes', 'boxerrorbars',
>>>> 'boxxyerrorbars',
>>>> 'vectors', 'financebars', 'candlesticks', 'errorlines',
>>>> 'xerrorlines',
>>>> 'yerrorlines', 'xyerrorlines', 'pm3d'
>>>> ==> Warning: BoundingBox not found!
>>>> "hist-eps.gplt", line 3: undefined variable: font
>>>> EPSTOPDF 2.9.3draft, 2003/04/20 - Copyright 1998-2002 by Sebastian
>>>> Rahtz et al.
>>>> !!! Error: 'hist.eps' does not exist!
>>>> "pattern-eps.gplt", line 3: undefined variable: font
>>>> Rahtz et al.
>>>> !!! Error: 'pattern.eps' does not exist!
>>>> "time-summary-eps.gplt", line 3: undefined variable: font
>>>> Rahtz et al.
>>>> !!! Error: 'time-summary.eps' does not exist!
>>>> "file-access-read-eps.gplt", line 3: undefined variable: font
>>>> Rahtz et al.
>>>> !!! Error: 'file-access-read.eps' does not exist!
>>>> "file-access-write-eps.gplt", line 3: undefined variable:
>>>> font
>>>> Rahtz et al.
>>>> !!! Error: 'file-access-write.eps' does not exist!
>>>> "file-access-shared-eps.gplt", line 3: undefined variable:
>>>> font
>>>> Rahtz et al.
>>>> !!! Error: 'file-access-shared.eps' does not exist!
>>>> LaTeX generation (phase1) failed [65280], aborting summary creation.
>>>> error log:
>>>> loading : Context Support Macros / PDF (2004.03.26)
>>>> ) (./job-table.tex)
>>>> Overfull \hbox (18.76118pt too wide) in paragraph at lines 39--39
>>>> LaTeX Warning: File `time-summary.pdf' not found on input line 43.
>>>> Error: pdflatex (file time-summary.pdf): cannot find image file
>>>> ==> Fatal error occurred, the output PDF file is not finished!
>>>> How should I debug this?
>>>> Regards,
>>>> Ketan
>>>> On 5/24/11 12:02 PM, Kevin Harms wrote:
>>>>> Ketan,
>>>>> Those files (home/ketan/darshan-install/share/*) should have
>>>>> been copied by 'make install'. darshan-job-summary.pl also
>>>>> requires gnuplot-4.2+ and pdflatex.
>>>>> You can check<source dir>/util/share and see if the files are
>>>>> there and then try make install and see where it tries to copy them.
>>>>> kevin
>>>>> On May 24, 2011, at 11:47 AM, ketan wrote:
>>>>>> Hello,
>>>>>> Now, I have been able to use Darshan as far as generating the
>>>>>> Darshan log from the binary execution. However, when I try to
>>>>>> generate the output.pdf report as shown in darshan wiki:
>>>>>> I get the following:
>>>>>> cp: cannot stat `/home/ketan/darshan-install/share/*.gplt': No
>>>>>> such file or directory
>>>>>> cp: cannot stat `/home/ketan/darshan-install/share/*.tex': No
>>>>>> Cannot open load file 'counts-eps.gplt'
>>>>>> line 0: util.c: No such file or directory
>>>>>> Sebastian Rahtz et al.
>>>>>> !!! Error: 'counts.eps' does not exist!
>>>>>> Cannot open load file 'hist-eps.gplt'
>>>>>> Cannot open load file 'pattern-eps.gplt'
>>>>>> Cannot open load file 'time-summary-eps.gplt'
>>>>>> font
>>>>>> variable: font
>>>>>> variable: font
>>>>>> <does not return??>
>>>>>> Any clue where to find the files (templates?) that it is missing?
>>>>>> Regards,
>>>>>> Ketan
>>>>>> _______________________________________________
>>>>>> Darshan-users mailing list
>>>>>> Darshan-users at lists.mcs.anl.gov
>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
More information about the Darshan-users
