[Darshan-users] Darshan installation question
    ketan
    ketan at mcs.anl.gov
    Mon May 23 18:19:58 CDT 2011
Hello,
I removed the said directive and did nm. I do get symbol table entries,
however I do not get any Darshan entries.
nm output attached.
Ketan
On 5/23/11 10:04 AM, Kevin Harms wrote:
> Ketan,
>    remove the "strip" command from the modftdock target, then you will still have symbols.
> kevin
> --- a/Makefile	2011-05-23 09:59:56.000000000 -0500
> +++ b/Makefile	2011-05-23 10:02:34.000000000 -0500
> @@ -59,7 +59,6 @@ all:		$(PROGRAMS)
>   modftdock:	modftdock.o $(LIBRARY_OBJECTS) structures.h
>   		$(CC) $(CC_FLAGS_FULL) -static -o $@ modftdock.o $(LIBRARY_OBJECTS) $(FFTW_LINKERS) $(CC_LINKERS)
> -		$(STRIP) $@
>   		$(SECURITY) $@
> On May 21, 2011, at 9:03 PM, ketan wrote:
>> When I do nm<myexe>  I get the following:
>> [bridled.ci.uchicago.edu:progs]$ nm modftdock
>> nm: modftdock: no symbols
>> Attaching the makefile that I used for compilation. That is where I use Darshan linked mpicc to compile my source.
>> Ketan
>> On 5/21/11 8:58 PM, Kevin Harms wrote:
>>> Ketan,
>>>    first thing, check that the library was linked in. Try nm exe | grep darshan and see if any darshan symbols are present. If they are, see if there is any output on standard error indicating the darshan log couldn't be opened.
>>>    If darshan isn't being linked in, are you also trying to use Tau or have other libraries that might intercept MPI routines.
>>> kevin
>>> On May 19, 2011, at 6:43 PM, ketan wrote:
>>>> Thanks Kevin for your help and support installing Darshan.
>>>> I now have Darshan installed and using its mpicc to make my application. However, I do not see anything gets touched in the designated Darshan logs when I really run the application.
>>>> Any ideas what to look for when debugging this.
>>>> Also, I do not know what should I send you guys so that you could possibly diagnose the issue.
>>>> Regards,
>>>> Ketan
>>>> On 5/18/11 11:41 AM, ketan wrote:
>>>>> I have now installed MPI, however, the installation stops at:
>>>>> configure: error: must provide --with-jobid-env=<name>   argument to configure.
>>>>>  From the INSTALL file, I see that if the above option is not provided Darshan uses the job-id.
>>>>> Could you kindly indicate how to get past this. Is there a default value that I could provide here?
>>>>> Ketan
>>>>> On 5/17/11 10:11 AM, Kevin Harms wrote:
>>>>>> Ketan,
>>>>>>    Darshan itself requires MPI. You could add MPI_Init(), MPI_Finalize() in your program main and that would be sufficient to get information about POSIX calls.
>>>>>> kevin
>>>>>> On May 17, 2011, at 10:08 AM, ketan wrote:
>>>>>>> Hello,
>>>>>>> I am new to Darshan. Trying to install on ci login node with the following commandline from the INSTALL file:
>>>>>>> ./configure --with-mem-align=64 --with-log-path=$LOGPATH --prefix=$PREFIX
>>>>>>> However, I get the following:
>>>>>>> configure: error: must provide --with-mpi=<path>    argument to configure if mpicc is not in path.
>>>>>>> The install file does not seem to mention mpi is mandatory. Is it possible to avoid the above flag while installation as our requirement does not include mpi.
>>>>>>> Thanks,
>>>>>>> Ketan
>>>>>>> _______________________________________________
>>>>>>> Darshan-users mailing list
>>>>>>> Darshan-users at lists.mcs.anl.gov
>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
>> <Makefile.txt>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20110523/2c0ea641/attachment-0001.diff>
More information about the Darshan-users
