[Darshan-users] Darshan installation question
Kevin Harms
harms at alcf.anl.gov
Mon May 23 10:04:09 CDT 2011
Ketan,
remove the "strip" command from the modftdock target, then you will still have symbols.
kevin
--- a/Makefile 2011-05-23 09:59:56.000000000 -0500
+++ b/Makefile 2011-05-23 10:02:34.000000000 -0500
@@ -59,7 +59,6 @@ all: $(PROGRAMS)
modftdock: modftdock.o $(LIBRARY_OBJECTS) structures.h
$(CC) $(CC_FLAGS_FULL) -static -o $@ modftdock.o $(LIBRARY_OBJECTS) $(FFTW_LINKERS) $(CC_LINKERS)
- $(STRIP) $@
$(SECURITY) $@
On May 21, 2011, at 9:03 PM, ketan wrote:
> When I do nm <myexe> I get the following:
> [bridled.ci.uchicago.edu:progs]$ nm modftdock
> nm: modftdock: no symbols
> Attaching the makefile that I used for compilation. That is where I use Darshan linked mpicc to compile my source.
> Ketan
> On 5/21/11 8:58 PM, Kevin Harms wrote:
>> Ketan,
>> first thing, check that the library was linked in. Try nm exe | grep darshan and see if any darshan symbols are present. If they are, see if there is any output on standard error indicating the darshan log couldn't be opened.
>> If darshan isn't being linked in, are you also trying to use Tau or have other libraries that might intercept MPI routines.
>> kevin
>> On May 19, 2011, at 6:43 PM, ketan wrote:
>>> Thanks Kevin for your help and support installing Darshan.
>>> I now have Darshan installed and using its mpicc to make my application. However, I do not see anything gets touched in the designated Darshan logs when I really run the application.
>>> Any ideas what to look for when debugging this.
>>> Also, I do not know what should I send you guys so that you could possibly diagnose the issue.
>>> Regards,
>>> Ketan
>>> On 5/18/11 11:41 AM, ketan wrote:
>>>> I have now installed MPI, however, the installation stops at:
>>>> configure: error: must provide --with-jobid-env=<name> argument to configure.
>>>> From the INSTALL file, I see that if the above option is not provided Darshan uses the job-id.
>>>> Could you kindly indicate how to get past this. Is there a default value that I could provide here?
>>>> Ketan
>>>> On 5/17/11 10:11 AM, Kevin Harms wrote:
>>>>> Ketan,
>>>>> Darshan itself requires MPI. You could add MPI_Init(), MPI_Finalize() in your program main and that would be sufficient to get information about POSIX calls.
>>>>> kevin
>>>>> On May 17, 2011, at 10:08 AM, ketan wrote:
>>>>>> Hello,
>>>>>> I am new to Darshan. Trying to install on ci login node with the following commandline from the INSTALL file:
>>>>>> ./configure --with-mem-align=64 --with-log-path=$LOGPATH --prefix=$PREFIX
>>>>>> However, I get the following:
>>>>>> configure: error: must provide --with-mpi=<path> argument to configure if mpicc is not in path.
>>>>>> The install file does not seem to mention mpi is mandatory. Is it possible to avoid the above flag while installation as our requirement does not include mpi.
>>>>>> Thanks,
>>>>>> Ketan
>>>>>> _______________________________________________
>>>>>> Darshan-users mailing list
>>>>>> Darshan-users at lists.mcs.anl.gov
>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
> <Makefile.txt>
More information about the Darshan-users
